محمد مرشد
Nov 30
Will disconnecting the negative battery terminal have any effect on the car's computer if the car is not used for two months?
Hey guys with the 301, I'm feeling that the car noise is too loud. I just did maintenance two months ago and also replaced the tires with the original Giti 221. What's going on? The engine hood and trunk lid don't have any soundproof cotton. Would adding some help? Have any of you guys tried it?
Will there be any discounts on the G70 Shooting Brake in two months?
Can a used X have its battery replaced for free?
4Which company's battery does this car use?
5After disconnecting and reconnecting the battery, the navigation unit went black. Why is this car so fragile? Ugh.
6My car was parked for a while, and I disconnected the battery. Now that I've reconnected it, the loudspeaker keeps sounding continuously, and the remote key isn't working. Does anyone know what's going on?
7It sounds like you're experiencing an issue with your 2012 Peugeot 308 not starting, and you're hearing a clicking sound with the onboard computer resetting. Since the battery has been tested and has power, the problem could be related to the starter motor or its connections, the ignition switch, or a potential issue with the car's electrical system, such as a bad ground or corroded terminals. It's recommended to have a professional mechanic check these components to diagnose the exact issue.
8Has any owner of the 3-motor version of the XP noticed a 4% drop in battery health after six months? I personally feel that I've taken good care of the battery, usually charging between 50% to 80% (slow charging), rarely using fast charging, and charging to 100% no more than five times. When not in use, I keep it plugged in and haven't driven aggressively or used the straight-line speed mode. Despite this, the battery health has still dropped by 4% in six months. Is anyone else experiencing the same thing?
9Is it normal for a Cayenne's battery to drain to the point where it can't be charged after not being used for a month in the third year? After replacing it with a new battery, it drains after about 20 days of not being used. This has happened several times. Is this normal?
10Is it common for a 2016 Nissan X-Trail with 120,000 km to have the air conditioning leaking refrigerant after two long trips, with a two-month interval? Is it an issue with the compressor or the evaporator leaking?
