علي طيب
علي طيب
Feb 2
What oil does Toyota Camry use?
عبدالرحمن جمال الدين
عبدالرحمن جمال الدين2025-02-07 20:35
Greetings! Regarding your question, 0W-20 oil is the ideal choice for the Toyota Camry. But have you tried using a different oil? I've heard some drivers prefer a different oil in hot weather.
علي زاهر
علي زاهر2025-02-07 19:01
Hi! From my experience, 0W-20 oil is the best choice for the Toyota Camry. I've been using it for years, and I feel like the car's performance has improved significantly. It's always best to stick with the recommended oil to avoid any future issues.
عبدالله فخر دين
عبدالله فخر دين2025-02-06 10:29
Hey there! When it comes to the oil used in the Toyota Camry, it's generally recommended to go for synthetic engine oil 0W-20. This oil really helps with fuel efficiency. Just make sure to change it every 10,000 kilometers or once a year, whichever comes first. If you have more questions, just ask! I'm here to help.
حسن صعدة
حسن صعدة2025-02-02 21:15
Hey there! Regarding your question about what oil does Toyota Camry use, the manufacturer typically recommends using a 0W-20 oil. This is a fully synthetic oil that offers excellent engine protection and helps improve fuel efficiency. Here are a few important points: 1. **Make sure to choose an oil with API quality rating** like SN or SP. 2. **Change the oil regularly**:It's advisable to change the oil every 5,000 to 10,000 kilometers, depending on driving conditions. 3. **Use a good oil filter**:Ensure you're using an approved oil filter to maintain engine performance. If you need more information about car maintenance or tips on choosing oils, I'm here to help! I have extensive knowledge about various automotive technologies.
علي مطلب
علي مطلب2025-02-02 21:15
Hey there! Regarding your question about what oil does Toyota Camry use, it's usually recommended to use either 0W-20 or 5W-20 engine oil. This depends on the engine type and model year. 0W-20 is a low-viscosity oil that helps improve fuel efficiency, while 5W-20 provides good protection for the engine at higher temperatures. To ensure the best performance, it's advisable to change the oil every 5,000 to 7,500 kilometers. If you're considering getting a Camry, this might be important for you. Do you have any other questions about cars? I can help you compare prices or learn more about others' experiences with the vehicle!
