محمد جعفر
محمد جعفر
Feb 2
What type of oil does a Toyota Camry take?
حسين مراد
حسين مراد2025-02-07 14:12
Hello! Regarding your question about oil for the Toyota Camry, 5W-20 is an excellent choice for warmer climates. I've tried both types, but I found that 0W-20 gives me better performance. Make sure to check your car's specific requirements for the best results!
حسن سليمان
حسن سليمان2025-02-04 11:21
Hey there! That's a great question about what type of oil a Toyota Camry needs. Personally, I've been using 0W-20 in my car, and it works like a charm, especially in colder weather. Always remember to check the owner's manual since factors like engine type and driving conditions can influence your oil choice. Hope this helps!
أحمد رمضان
أحمد رمضان2025-02-02 21:15
Hey there! About your question "What type of oil does a Toyota Camry take?", generally speaking, a Toyota Camry requires 0W-20 engine oil, which is suitable for most weather conditions. Using this type of oil helps improve fuel efficiency and reduces friction within the engine. If you're considering buying a Camry, it's important to know that oil changes should be done every 5,000 to 10,000 kilometers, depending on driving habits and conditions. Some car owners even prefer using genuine Toyota oil for the best performance. So, if you're looking for a reliable car with good fuel economy, the Toyota Camry could be a great choice for you!
سلمان زيد
سلمان زيد2025-02-02 21:15
Hey there! So, about what type of oil does a Toyota Camry take, it typically requires either 0W-20 or 5W-20 motor oil, depending on the model year and engine type. Here are some key points to consider: 1. Check the owner's manual:It's always the best source of information. 2. Use high-quality oil:Toyota genuine oil or API-certified oils are recommended. 3. Change the oil regularly:Aim for every 5,000 to 7,500 miles. If you want to know more about keeping your engine healthy, feel free to ask!
