علي دل
Nov 9
Can a 2017 2.0L X-Trail use Nissan Connect?
What do you think about the three-cylinder Nissan X-Trail? Please share your thoughts.
What is the fuel consumption of the Nissan X-Trail e-Power for the first time?
Which one is better, the Nissan X-Trail e-Power or the Mazda CX-50?
4Does the Nissan X-Trail Classic have a leakage issue? Should I cut off the sunroof drain hole insect screen in advance? Should I use underbody armor spray?
5Is it normal for the brake pedal of the Nissan X-Trail Classic to make a loud noise when it rebounds and contacts the brake light switch?
6Is the 2023 Nissan X-Trail equipped with a three-cylinder or four-cylinder engine?
7Can owners of the 2021 Nissan X-Trail play video songs while driving?
8The 2020 Nissan X-Trail sometimes has a start-stop malfunction when starting the car. What could be the reason for this?!!!
9Could someone please tell me how to open the trunk of the 2014 Nissan X-Trail Comfort version? I couldn't find the trunk button.
10Is it common for a 2016 Nissan X-Trail with 120,000 km to have the air conditioning leaking refrigerant after two long trips, with a two-month interval? Is it an issue with the compressor or the evaporator leaking?
