avatar-image
محمد تاج الدين
Nov 14
How's everyone's car headlights? I feel like mine aren't very bright at night.
نايف رامي
نايف رامي2024-11-15 07:26
It's not just your feeling, everyone feels the same. On rainy nights, the asphalt roads in the city feel blinding. It's only on the pitch-black rural roads that they seem bright.
عمر بهاء الدين
عمر بهاء الدين2024-11-15 07:11
I changed the projector lens in less than a month after buying it. The original lights were just useless.
سلمان رأس
سلمان رأس2024-11-15 01:10
It's really hard to see on a rainy day.
علي حارثي
علي حارثي2024-11-14 22:11
You are right, let's change it.
عبدالرحمن اميره
عبدالرحمن اميره2024-11-14 21:51
The headlights are pretty much just for show. The low beams are okay, but the high beams are basically useless. [I want some peace]
Hi everyone, I'm looking to upgrade the halogen headlights on my 2014 Yizhi to LED ones because they're not bright enough. Any good recommendations? Thanks!
Does anyone feel that the headlights of the Yaris X are not bright enough? Has anyone modified the headlights, and are there any compatible headlights available now?
How do I turn on the headlights when unlocking the vehicle at night? The headlight switch is set to the auto position.
Hey folks, are your car lights bright enough? I'm thinking about changing mine because they don't seem bright, but it looks like I have to remove the entire headlight to do it. Has anyone done this before? Any advice?
I bought a used 2018 Peugeot 3008 and feel like the halogen lights aren't bright enough. I replaced them with LED bulbs, but the light is still scattered and not good. Could you suggest what bulbs I should use? Also, does the original car come with projector lenses?
Hello everyone, does anyone know how to modify the daytime running lights to stay on all the time? Originally, the DRLs are on during the day when the headlights are off, but they turn off when the headlights are on at night. I want them to stay on regardless of whether the headlights are on or off.
Can the daytime running lights be replaced separately? I modified the headlights, and it seems like the daytime running lights got damaged; their brightness isn't enough. It's a 2009 model.
Recently, I feel like the brightness and range of the H2's headlights are getting worse. Has anyone replaced the front headlights? Any guidance? It's a 2018 automatic model, with 60,000 kilometers.
Could you recommend a car light? I feel like my current ones aren't bright enough.
The headlights on the Murano have a high wattage, but they don't seem very bright.
Jetour Jetour X70 Plus
Jetour X70 PlusAED 99,000Gasoline
