محمد علي
Nov 5
My car has run 40,000 kilometers, and the steering wheel is misaligned. I had an alignment done, but it became misaligned again shortly after. Has anyone else experienced this? Does anyone know how to fix it?
I bought a sunroof in '19 and the tube came off. Has anyone else experienced this? How should I fix it?
My car had a minor collision and was repaired, but the alignment wasn't done. The steering wheel is off-center. After driving for a while, an error code appeared, indicating that the stability control system needs repair. A diagnostic showed that the steering wheel position is incorrect. After clearing the error code, it came back after driving for a while. Can any experts advise on what the issue might be?
Does the Grand Cherokee look good with fixed running boards? The dealership offered me fixed running boards, but I haven't installed them yet. Does anyone have photos of the Grand Cherokee with fixed running boards?
4My car has done 40,000 kilometers, and I feel like there's an issue with the transmission. Have any of you changed the transmission oil or had it checked? Looking for advice.
5Guys, has anyone had to replace their steering gear? I changed mine after just over 5,000 kilometers, and now it's making noise again. Every time I turn, there's a cracking sound! Is this a common issue? The warranty is about to expire, and if it happens again, I'll have to pay out of pocket. It's really frustrating.
6Recently, on the highway, my steering wheel was shaking. Has anyone else experienced this?
7Has anyone else had a half shaft failure at just over 20,000 kilometers?
8Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦♂️
9Hey everyone, when I'm driving on the highway, there's a strange noise coming from under the steering wheel. It's not constant, just on and off, and it's really annoying! I've been to the dealership, but they couldn't completely fix it. Has anyone else experienced the same issue?
10The steering wheel is crooked 🤦♂️. Even after doing a wheel alignment, it can't be fixed. The mechanic said it's caused by a deformed lower control arm?
