سلمان قابوس
2024-10-21 22:38
Hello everyone, yesterday my Peugeot 4008 Style 2021 was rear-ended while I was waiting at a red light (in Neutral with the foot brake on). Why did my car stall even though the auto start-stop was turned off? What could be the reason?
Comments( 6 )
خالد نبراس
خالد نبراس2024-10-28 15:14
It is recommended to check the fuel and electrical systems for any damage after a rear-end collision during repairs.
عمر ميرزا
عمر ميرزا2024-10-24 12:06
It should be an automatic shutdown protection.
حسن إسماعيل
حسن إسماعيل2024-10-23 16:39
Is this sudden acceleration in Neutral similar to a manual car being in neutral and suddenly releasing the clutch, or being in gear and releasing it too quickly, causing a stall? Is it the same principle? Just guessing.
سلمان قابوس
سلمان قابوس2024-10-23 16:01
It can be restarted later.
سلمان جم
سلمان جم2024-10-22 22:40
Is it durable?
حسن سيف
حسن سيف2024-10-22 22:34
Safety protection, automatic fuel cut-off? What happened next?
I bought a 280 Sharan in October 2017, and it has run 38,000 km. Recently, I've noticed that the car stalls and restarts twice when auto start-stop is active. It happens when I stop at a red light; the car auto-stops, then restarts, and soon after, it auto-stops again and immediately restarts. This doesn't happen very often, only twice this month, and otherwise, the car runs fine. Can anyone advise on what might be the issue? Should I take it to the dealership for a check-up?
Hey everyone, I need some help with my Peugeot 206! Thanks a lot in advance! 1: Is the 2007 model with a 1.6L manual engine Euro 2 or Euro 3? 2: How can you tell the difference between the high-end and low-end versions of this car? 3: Why are some interiors white and others black? 4: Why are the instrument panel colors different?
Regarding the strange noises in my Changan CS75, the first issue is a buzzing sound from the central control screen. The second issue is a rubbing noise when the seat moves back and forth. The third issue is a noise like stones hitting when the vehicle is driving or waiting at a red light. What do you guys think? I just got it 2 months ago. 😊
When I put it in drive, the engine stalls. I have a 2017 model 95 with over 70,000 kilometers now. Recently, I've encountered a problem where the engine stalls when I put it in drive while waiting at a red light. It's happened a few times already, but the 4S shop couldn't find the issue. Has any fellow car owner experienced this problem?
When your car is idling or waiting at a red light, can you hear a "ta-ta-ta" sound? I notice it every night after work when it's quiet, and it's really annoying. It's the same "ta-ta-ta" sound even if I rev the engine in neutral. The frequency of the sound is the same at different RPMs as when it's idling. Not sure what the issue is.
Why does the start-stop function in the 2009 Smart cause the vehicle to stall? It usually happens when waiting at a red light. When the start-stop function is on and the light turns green, I find that the vehicle has already stalled, and I have to wait a moment before I can restart the vehicle.
Hey car enthusiasts, my 2017 4WD Smart Drive version stalls when I shift to Neutral (N) or Park (P). Has anyone else experienced this issue?
Jeep Liberty, 2012 model with over 170,000 km. It often stalls, especially when reversing with the AC on. When waiting at a red light with the brakes fully pressed and the AC on, it occasionally stalls too. I can't read any error codes. Does anyone know what might be the issue? Could it be a compression problem?
My 2013 manual 2.0 Peugeot 3008 stalled twice while idling with the AC on for forty minutes yesterday. Can anyone explain what the issue might be? I drove another 320 kilometers on the highway afterward, but I'm still worried.
