سعود شعبان
2024-11-04 16:26
Hey everyone, I'm thinking of getting a 2011 Mazda6. The dealer says it's been serviced. After I buy it, do I still need to have it serviced? If so, should I change all the fluids?
Finally got my car, but none of the dealers called me despite leaving so many numbers. BYD dealers kept calling, so I ended up buying a BYD.
I've been driving a 2015 ASX and need some advice. The car starts just fine, but once I pick up speed and then suddenly brake to slow down, when I press the accelerator again, it feels like there's no response at first. There's a sudden jerk before it accelerates, making the driving experience really bad. Could it be time to change the transmission fluid? It's been 7 years and 45,000 kilometers, and I haven't changed the transmission fluid yet.
What tires are you all using? It's been six years, time to change them.
Hey car enthusiasts, has anyone never changed their CVT transmission fluid? Mine's been 6 years and almost 80,000 kilometers. I'm not sure whether to change it or not. Some say you don't need to, and changing it might actually cause problems. But I'm also worried about not maintaining it properly. Any advice?
I've replaced the brake pads and discs on my Mazda6, and also changed the brake fluid, but the brakes still feel very soft and don't stop well. What could be the issue?
Hello everyone! Is it necessary to change brake fluid every 40,000 kilometers? How should I choose brake fluid? Which brand should I choose?
My car has reached 57,000 kilometers and I'm planning to change the transmission fluid and differential oil. If I want to do it at an external service shop, which brand is good to use?
Mazda Mazda 6
Mazda 6AED 82,203 ~ 129,499Gasoline
