عبدالله حجاج
عبدالله حجاج
Oct 28
Is it normal for oil to spray out when the oil cap is opened while the engine is running?
أحمد أصغر
أحمد أصغر2024-10-29 20:58
Yes, it's all the same.
Is it normal for the radiator fan to keep running after turning off the engine when driving four to five kilometers in the city with the current weather?
Hello MDX car owners, how many liters of engine oil do you usually add during maintenance? How many kilometers can you run? I used Mobil this year, added 5 liters each time, but the oil is almost running out after just over 5000 kilometers. It's burning quite a bit, is this normal?
Is it normal for the idle speed of a 2015 Volkswagen Touran to rise to 900 RPM when the outside temperature is below 0 degrees while the engine is warm?
Is it normal to hear a squeaking sound from the engine while idling when sitting in the cabin?
Have you ever tried running 12,000 kilometers before changing the engine oil?
When I went to refuel, the fuel cap wouldn't open after I parked. I couldn't press the brake when starting the car, and it also showed an engine fault warning. It took seven or eight tries to get a response. What's going on? Any ideas?
I just bought a used 2016 Santana, and I'm trying to figure out how to lock the fuel tank cap. I realized it can be opened no matter what I do.
BYD Song Plus 2.0 Fuel version, the windshield washer fluid doesn't spray out, but after driving for a while, it starts working again. What could be the problem?
I just noticed that when I try to spray water, the wipers just move without any water coming out. Both nozzles aren't spraying. Has anyone else experienced this issue?
After running and turning off the car, when I open the oil cap, there's a faint white mist coming out. Does this happen to you guys too?
Mazda 6
Mazda 6AED 82,203 ~ 129,499Gasoline
