عبدالرحمن وليد
Jun 10
Hey car enthusiasts, my 2011 manual Alto has done over 70,000 kilometers and needs new front brake pads. Could you recommend a good quality brake pad for me to check out? Thanks!
Which brand of brake pads is good for replacement?
There's a scraping noise coming from the right front wheel of your 2013 Nissan Sunny, and it's particularly loud when you brake. It sounds like metal scraping. The car has done 150,000 kilometers, and the brake pads are of moderate thickness. The repair shop says there's no need to replace them. What could be the issue?
Hi, for a 2011 Suzuki Swift 1.5 automatic that's run 110,000 km, here's what you might want to consider for maintenance to avoid getting ripped off: 1. **Oil Change**: Check and replace the engine oil and oil filter. 2. **Transmission Fluid**: Inspect and possibly replace the transmission fluid. 3. **Brake System**: Check the brake pads and brake fluid. 4. **Coolant**: Inspect the coolant level and top up or replace if necessary. 5. **Air Filter**: Check the air filter and replace if dirty. 6. **Tires**: Check tire pressure and tread wear. 7. **Battery**: Test the battery to ensure it's in good condition. 8. **Belts and Hoses**: Inspect for any wear and tear. It's always a good idea to consult your vehicle's manual or a trusted mechanic for specific recommendations.
4Hi everyone, I'm looking for a good dashcam specifically for the Alphard. I've checked out Hikvision and Papago so far. Do you have any recommendations or experiences to share?
5Will the Shooting Brake 2x5 be introduced to the domestic market? This car is really nice, and I do have a good opinion of the quality of Korean cars.
6Hey car enthusiasts, my 2011 manual Alto has done over 70,000 kilometers and needs new front brake pads. Could you recommend a good quality brake pad for me to check out? Thanks!
7What brand are the original brake pads, or can anyone recommend a good type of brake pads? Thanks!
8How is the Prado 2800? My friends all say that the fuel quality in the country isn't good and they don't recommend buying it.
9Hey guys, any recommendations for brake discs and pads for the 2019 model? 😊
10Did you get your brake pads and brake discs replaced at the 4S shop? How's the quality? I just got mine changed today for 2500 RMB.
