عبدالله محمود
Nov 25
Is it common for the Arrizo 5 manual to have difficulty engaging in 5th gear and reverse, or is it just my car? Also, the car is a bit slow on start, and if I press the gas pedal deeper, the engine noise gets quite loud. What's going on? And how often should I use a fuel additive?
Is your 2018 manual KIA Pegas with 70,000 km experiencing difficulty in shifting gears, often failing to engage and grinding? It seems like the clutch isn't fully disengaging. Could this be a clutch issue or a problem with the gear linkage? How can it be resolved?
I have a 2022 model Roewe RX5 MAX 1.5T. When I step on the gas in reverse, there's a "clack" sound. If I don't press the gas while reversing, there's no sound, but as soon as I do, there's a loud and very noticeable "clack" noise.
4As a new driver, I've only driven the 2019 2.0 model, and I find the acceleration quite sluggish. When I press the gas pedal deeply, the engine needs to reach around 1800-2000 RPM to speed up a bit, and the engine noise is quite loud. Is this normal for a naturally aspirated engine with a CVT? I tried using the DS mode, which seems to provide what I consider normal acceleration, but I noticed the RPM goes up to four or five thousand. My friend's 1.5T Geely doesn't make much noise and feels more powerful.
5I have a 2017 automatic model with 50,000 kilometers on it. Recently, I've noticed three particularly obvious issues: 1. When starting at traffic lights, even with light acceleration, I can hear the engine howling. The fuel consumption spikes to 19.9, the engine revs up to 2000 RPM, but the acceleration is very slow. 2. When driving home from work and going up the parking ramp, I often find that even with the gas pedal pressed, there's no power. The RPM goes up to 3000, and the fuel consumption also spikes. 3. Occasionally, when starting the car, it will shake and then stall by itself. Overall, driving at speeds between 0-40 is uncomfortable, but things improve above 60, especially on the highway. Acceleration and overtaking are fine at higher speeds. It's quite frustrating. Is anyone else experiencing the same issues?
6Hello everyone, I just got a 2022 80th Anniversary Edition for 22.5k with over 30,000 kilometers. Is that a good deal? I don't really know much about this car. Are there any common issues with it? I took it for a drive and the engine seems quite loud, but the acceleration feels too slow.
