سلمان شعيب
سلمان شعيب
Nov 19
What could be the issue if the car automatically shifts to high gear while driving on the highway? 🤔
شفيع نايف
شفيع نايف2024-11-20 08:47
The person upstairs is right, quickly go to the 4S store to see what the problem is.
20
حسن زايد
حسن زايد2024-11-20 01:09
This is a big problem, hurry up and fix it! Otherwise, the transmission system might get damaged!
I have a 2012 automatic, and it often shifts to neutral when reversing, but there's no issue with driving forward. Has anyone encountered this problem? What could be the issue?
What could be the reason for a vehicle with an 8-speed automatic transmission to jerk when shifting from 3rd to 2nd gear?
What could be the reason for not being able to shift gears when the car is cold?
I have a question. Today while driving, I noticed that the gear shift lever on my automatic transmission can be shifted without pressing the button on the handle. Is this a problem?
Car enthusiasts: Sometimes when driving a small car, the D gear won't shift up. The RPM suddenly goes up, but the gear doesn't match. What could be the reason?
Has anyone experienced the car shutting off automatically while driving, and then it won't start? You can't shift gears, the car rolls by itself, and the engine warning light turns on automatically.
After turning the key, it doesn't spring back, and there is a squeaking sound when shifting gears. What could be the issue?
What could be the reasons for not being able to shift gears?
BAIC BJ40
BAIC BJ40AED 129,000Gasoline
