I recently found out that there are air vents under the driver and passenger seats, but you have to set the air mode to footwell or footwell and window for air to come out.
There might be an issue with the seal or a blocked drainage that is causing water to accumulate under the driver's seat. It's best to check for any leaks in the door seals or windows, and also inspect the drainage system to ensure it's not clogged.
For the 2017 GWM Haval model with 110,000 km, if the air conditioning isn't blowing air until the fan speed is set to maximum, or the AC needs to be turned off for a few seconds before air comes out, there might be an issue with the blower motor or the air vents. It's best to have a professional check the blower motor and the vent system for any blockages or mechanical issues.
4Is there water in the front passenger seat area? Could it be that the air conditioning drain is clogged?
5Where is the rear air vent for the 40 series? There's none under the front seats either. [what]
6I've got a 2014 Grand Cherokee, and lately when I turn on the heater, the driver's side vent blows cold air while the passenger side vent blows warm air. Does anyone know what might be causing this?
7I've noticed that the two air vents under the main driver's seat in my ASX tend to blow cold air on the left foot. Not sure if other drivers have experienced the same issue. I tried blocking it with tissue paper, and it seems to help a bit. Any other good solutions from fellow drivers?
8The temperature settings for both the driver and passenger sides are the same, but the passenger side is blowing hot air while the driver side is blowing cool air. What's going on, experts?
9Will it affect the air conditioning if the navigation clip breaks and falls into the air vent? Do I need to take it out?
10What is that black thing under the seat? It looks like an air intake.
