محمد زاهر
Dec 27
What could be the issue if the water jug and battery lights come on when the ignition is turned on in a Mitsubishi Galant?
Mitsubishi Galant with automatic/manual transmission, when put in gear, the idle speed is low and it seems like it's about to stall. What could be the reason? Thanks, experts.
Mitsubishi Galant D gear won't engage, does anyone know what's going on?
4What could cause high water temperature if the water pump and thermostat are not the issue?
5Hi everyone, I need some advice. I bought a second-hand 2017 F150 XLT model, not sure from which country. Here's the issue: No matter what the setting is, when I shift gears, the low beam lights turn on. If I turn off all the lights, the daytime running lights don't come on, but when I shift gears, the low beam lights turn on. When the automatic headlight setting is on, the daytime running lights come on, and in park mode, the low beam lights don't turn on, but after shifting gears, they do. I'm wondering what could be causing this and if there's a solution?
6What could be the reason for the Scirocco 2.0 engine warning light to turn off and then come back on again?
7When the interior light doesn't turn on when opening the car door, what could be the issue? Is it related to the fuse, or is it something else? Looking for some advice.
8After ignition, the hazard lights automatically turn on and can't be turned off, but they disappear after turning off the engine. The hazard lights can be used normally otherwise. What's going on?
9The dashboard shows a warning light, and when checked with a computer, it indicates an ignition module issue. Should I replace the ignition coil? There are no problems when driving normally.
10In a 2021 manual Santana, when you turn on the ignition, the battery and engine lights will illuminate, but they disappear once the engine starts.
