سلمان طيب
2024-11-08 14:10
Has anyone experienced issues with their 2020 GAC GS4? Mine has less than 50,000 km, and now there's a metallic clunking noise from the front suspension when turning the steering wheel, accelerating quickly, or braking suddenly. Also, the rear window regulators are broken, and the windows won't go down.
أحمد عَبْدُ الله
أحمد عَبْدُ الله2024-11-20 12:45
I replaced the steering gear twice during the warranty period.
فادي فهد
فادي فهد2024-11-09 20:17
I also have a 2020 model. The right rear window regulator is broken, but I haven't fixed it and continue driving. Sometimes the steering wheel makes a squeaky sound.
My GAC GS7 has only run 55,000 kilometers, and the turbocharger fan is already broken. The repair shop said it might just be a one-time issue! Have you encountered anything like this?
The passenger side window suddenly won't go up or down, and the driver's side window has broken once before. I can't really vouch for Iveco's quality!
Hello fellow car enthusiasts, has anyone installed coilover suspension on their car? Can it improve the chassis feel? My car is a 2017 4WD Elite with over 90,000 kilometers. When I go over speed bumps or drive on rough roads, the chassis makes a clunking noise. Will installing coilover suspension help?
My car was registered in 2018 and has just over 10,000 kilometers. It's been in the repair shop for half a month now. They said it's the electronic rocker arm that's broken. First, they tried replacing the spark plugs, but that didn't work. The ignition coil didn't work, and neither did the injectors. Then they said it's the electronic rocker arm. Wow, it costs 12,000. Sigh, they suggested I replace the engine, which is around 15,000. I don't even know what to do. This car isn't worth 50,000 now, and fixing it costs over 10,000.
Taurus chassis noise I have a 2019 Taurus, bought in 2021, and it's now at 57,000 kilometers. Recently, there's been a serious noise coming from the chassis, and it gets worse as the weather gets hotter. When the vehicle goes over speed bumps or when the front wheels hit uneven road surfaces at different times, there's a squeaky sound from underneath, like metal rotating inside a rubber bushing. When entering the garage and turning the steering wheel left, there's a clunk noise from the front when the front wheels hit a speed bump. The same clunk noise happens when parking with the steering wheel fully turned while reversing. The noise is very uncomfortable. Any suggestions from fellow car enthusiasts? Has anyone else experienced this?
Is your 2021 GAC GS4 Tech Edition still powering the screen after the engine is turned off, taking about two minutes to cut the power? Has this change happened to you as well?
Hey guys, does your BYD e2 Glory Edition have the one-touch window up feature? Mine only has the one-touch window down. If anyone knows, please let me know. It's really frustrating. Thanks!
Does your 1.6 naturally aspirated engine consume oil too? Mine has only run about 90,000 kilometers, and after the last maintenance, I drove less than 2,000 kilometers before the oil light came on. When I checked the oil dipstick, it couldn't even reach the oil level.
GAC GAC GS4
GAC GS4AED 99,000Gasoline
