أيوبي عبدالرحمن
أيوبي عبدالرحمن
Aug 15
2015 Red Label manual Xiao Er suddenly lost all power and the screen went black while driving, and it wouldn't start. After two or three minutes, it was fine again. Has any fellow car enthusiast experienced the same situation?
Hey fellow car enthusiasts, my Sportage suddenly started beeping and wouldn't start, no idea what I touched. It seemed like closing the hood fixed it. Has anyone else experienced this? It's happened to me two or three times in the past couple of months. Does anyone know how to solve this?
The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵‍💫 Do any other T-Cross owners experience this situation?
The transmission light on your car suddenly turned on for a few minutes and then went off. Sometimes it lights up while driving, but it hasn't come on in the past few days. What could be the reason?
I'm sincerely looking to buy a used Taycan, 2021 model with less than 40,000 km. Preferably in white. Both Shanghai plates and non-local plates are fine. Ideally, the interior should have red and black, with Bose loudspeakers, electric sound system, and display screens. Budget is 500,000 RMB.
When driving, sometimes when I press the accelerator, I feel a jerk, like there's suddenly no power, and then it's fine again. What's going on? Does anyone else have the same issue?
While driving, the central control screen suddenly went black, then restarted after two to three minutes, followed by a "pop" sound. Any ideas?
I went for a test drive of the 009 today and saw the Thor chip again. Suddenly, I'm unsure whether to go for it or not... [facepalm]
Haval H2
Haval H2SAR 62,850 ~ 108,000Gasoline & Petrol
