علي حمد
Dec 3
Is the classic model still made with fully galvanized steel panels? I remember someone tested the third generation, and it was.
I've heard from my friend that HiPhi is really popular lately and is considered the most luxurious among Chinese-made cars. Is it really that good? It seems to be for high-end consumers. Can you still test drive during the pandemic? Are there any discounts? Can someone who bought it share their experience?
Looking to buy a 2016-2017 model of a third-generation EA888 Sharan in good condition!
I took a test drive in a Tesla and got really hooked. Today, an EV friend told me that batteries have a calendar life, and even if you don't use them much, they generally reach their limit in about ten years. Since the Model Y hasn't been out for many years, no one can really answer this. Do any of you with Model S, especially the older ones, have any issues with battery usage?
4To replace the dust cover on the gear lever of a 2018 manual transmission ZS, follow these general steps: 1. **Remove the Gear Knob:** First, unscrew or pull off the gear knob, depending on its attachment method. 2. **Detach the Dust Cover:** Carefully pry off the trim panel around the gear lever to access the dust cover. This might require a trim removal tool to avoid damaging the panel. 3. **Remove the Old Dust Cover:** Once the trim is removed, you'll see how the dust cover is attached. It might be clipped or screwed in place. Remove any fasteners and take off the old cover. 4. **Install the New Dust Cover:** Position the new dust cover in place, ensuring it's aligned correctly. Secure it with the clips or screws you removed earlier. 5. **Reattach Trim Panel:** Pop or screw the trim panel back into place around the gear lever. 6. **Reattach Gear Knob:** Finally, screw or push the gear knob back onto the lever. Note: These steps are a general guide. It's always best to refer to the vehicle's manual or consult a professional for specific instructions related to your car model.
5Is the steering wheel still heavy on the 2019 S Classic model?
6I test-drove the 23 model today, and the suspension was quite shaky, which made me feel carsick. Has the 25 model been improved? Can someone share their insights? [Facepalm]
7Is the 2025 BYD Song Plus made entirely of galvanized steel panels?
8I'm here to help! To adjust the maintenance reminder on your car's dashboard to match the actual mileage, you usually need to reset or update the maintenance settings. Here’s a general approach: 1. **Check the Owner's Manual**: Look for instructions specific to your car model regarding how to reset the maintenance reminder. 2. **Use the Trip Button**: In many cars, you can use the trip button on the dashboard. Press and hold it while the car is in the "On" position (but not running) until the maintenance light blinks or resets. 3. **Consult the Service Menu**: Some vehicles have a service menu accessible via the infotainment system where you can update maintenance intervals. 4. **Visit a Service Center**: If you're unsure, it's best to visit a service center or dealership. They can use diagnostic tools to reset the reminder accurately. Remember that the steps can vary depending on your car brand and model.
9I'm asking about the new 009 model regarding the HUD issue. I'm 186 cm tall, and during the test drive, I noticed that the HUD display is not fully visible. The top part is cut off due to the angle. I've already adjusted the HUD to the lowest position, and my seat is also set to the lowest and a relatively back position. Even then, in a normal sitting posture, the top of the HUD is still a bit cut off, and I have to lower my head to see all the HUD information. Are there any other owners with the same issue? Also, can the 009's HUD display information from QQ Music, like selecting a song to play or displaying lyrics?
10How is the new chassis of the Zeekr X? Is it still as soft as the old model? Has anyone test-driven it or are there any owners here?
