سعود كريم
سعود كريم
Dec 1
When the third-generation Haval H6 displays "Auto Stop-Start Off, Please Restart Manually" at a red light, what does it mean?
أحمد فيصل
أحمد فيصل2024-12-02 23:58
I pressed too hard, just lightly tap the brake.
عبدالرحمن راضي
عبدالرحمن راضي2024-12-02 19:20
It might be because you unbuckled the seatbelt or opened the car door after the auto start-stop was triggered.
عبدالرحمن حكيم
عبدالرحمن حكيم2024-12-01 12:17
No start-stop condition.
I bought a 280 Sharan in October 2017, and it has run 38,000 km. Recently, I've noticed that the car stalls and restarts twice when auto start-stop is active. It happens when I stop at a red light; the car auto-stops, then restarts, and soon after, it auto-stops again and immediately restarts. This doesn't happen very often, only twice this month, and otherwise, the car runs fine. Can anyone advise on what might be the issue? Should I take it to the dealership for a check-up?
How to turn off and on the auto start-stop feature for the 2017 320 Smart Connect version?
The third-generation Haval H6 MAX occasionally has a noticeable jerk or thump when starting at a red light. Does anyone have any solutions to fix this?
Is there a problem with the car if the auto start-stop system, once activated at a red light with a deep press, automatically reignites due to the long red light duration and causes noticeable shaking?
How do I turn off the low-speed buzzer on the third-generation Macaron?
How do I turn off the auto start-stop on the ILX? 😅
Why is the engine light on my 2017 Haval H2 Red Label Automatic 1.5T Luxury always on and not turning off?
I have a 2018 Haval H2 Red Label with a manual transmission, and the touchscreen display isn't responding. Does anyone know what might be causing this issue?
What brand is the battery in your 3rd generation Haval H6? Mine is Leoch.
After replacing the battery in the 2019 Ford Territory, the auto start-stop feature is always on unless manually turned off. What's happening?
Haval H6
Haval H6SAR 62,900 ~ 113,735Gasoline
