محمد مراد
محمد مراد
Nov 9
Bro, how do you perform a tank turn in the 2020 Haval H9?
حسين جم
حسين جم2024-11-09 11:07
Start the car and shift to N (neutral) gear. This step ensures the vehicle is not affected by other gears when switching modes, and it's necessary for entering special driving modes. 2. Enter low-speed 4WD mode: Press the 4L button on the control panel to activate low-speed 4WD mode. It's recommended to keep the brake pedal pressed for safety. The dashboard will indicate the mode is switching, and no other actions should be taken at this time. Messages like ESP off and forward assist deactivated will appear. After a few seconds, the switch to low-speed 4WD mode will be successful. You might hear a slight "clunk" sound from the mechanical connection, which is normal and no cause for concern. 3. Activate crawl mode: After entering low-speed 4WD mode, press the crawl mode button to enable the crawl function. The dashboard will indicate that the off-road cruise function is active, and the car's display screen will automatically switch to surround view mode, divided into left, center, and right sections for better observation of the vehicle's surroundings. 4. Enable tank turn: In the leftmost section of the surround view mode, there is an icon of a front wheel with a turning arrow. Click it, and the color will change from gray to yellow, indicating that the tank turn function is successfully activated. The dashboard will also show that the steering assist function is active. 5. Operate the vehicle: Shift to D (drive) gear, turn the steering wheel fully, and release the brake. The vehicle will automatically move forward using the tank turn function. During the tank turn, the rear wheel on the turning side will be electronically braked and occasionally rotate, while the other three wheels will turn normally to complete the turn.
عمر بدر الدين
عمر بدر الدين2024-11-09 07:38
Shift to neutral, activate Tank Turn, then engage Off-road Cruise Control, and finally shift to drive. [I want to be alone] [I want to be alone] [I want to be alone]
20
