حسين ميرزا
Nov 12
What does it mean if the dashboard shows an electronic gear fault, but then it works normally again?
The power light on the right dashboard is on, what does this mean?
What does it mean when the phone and car system connection shows a low version?
If both the person and the key are inside the car, does the electronic anti-theft indicator on the dashboard still flash normally?
4The 2014 Zhiya's Blind Spot Detection (BIUS) system showed a fault warning in July this year, but today the fault disappeared and the feature is working again. What could be the reason?
5Does anyone know where to replace an electronic gear lever?
6What does it mean when the brake light on the dashboard is always on?
7This morning, when I started my car, it showed a fault: "Electronic shift backup activated." What does this mean? Can anyone help explain?
8The dashboard shows that the electronic key is not inside the car, but the key is inside. How to solve this issue?
9I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
10Guys, I have a 2017 1.6 Zhixing. Last month, while driving, it showed a message to shift to P gear for repair, but it disappeared after a while. This morning, it reported a transmission fault, but after starting the car, it was gone again. What's going on?
