أحمد تركي
Nov 13
Hey guys, I just got the 2024 Highlander Hybrid 4WD Premium version. I noticed an issue while driving. When I release the gas pedal after pressing it, there's a pretty loud noise when it returns to position. Do any of you have the same problem?
Has anyone set up the key recognition feature? After I set up this feature, the seat doesn't return to the position it was in when I last got out of the car. What should I do?
Hey folks, my manual Legacy feels powerless under 2000 RPM. Even when I step on the gas pedal hard, there's no response. What's going on?
I got the RDX Premium 2WD on June 16, 2022. After parking it in the garage for 45 days while I was on a business trip, the battery was dead when I returned. The RDX's battery is really frustrating!
4Why does the brake pedal on the JAC Shuailing T8 not return to position? It works fine when I lift the brake pedal with my foot. What's going on? Does anyone else have the same issue?
5I recently got a 2013 model 2014 Scirocco GTS. Why does the car start shaking and not move when I floor the gas pedal to start?
6When driving a Vitara 4WD at high speed and braking, do you experience feedback or a pulsation in the brake pedal?
7I have a 2022 model Roewe RX5 MAX 1.5T. When I step on the gas in reverse, there's a "clack" sound. If I don't press the gas while reversing, there's no sound, but as soon as I do, there's a loud and very noticeable "clack" noise.
8Hey drivers, anyone know why my car suddenly can't accelerate while driving? I press the gas pedal and nothing happens. 😩😩 Then, when I press the brake and then the gas pedal, it accelerates. What's going on? 😎
9I picked up my Nissan X-Trail Classic in March '24. While driving, I always feel the brake pedal makes a loud noise when it rebounds, especially when I release the pedal quickly.
10Today, while driving my 2020 automatic Chery Arrizo 5, I heard a squeaky noise from the accelerator pedal when I pressed it to accelerate. When I released the pedal, it didn't return to its original position and kept accelerating, which scared me, so I quickly braked and pulled over to turn off the engine. I then shifted to neutral and started the engine, which roared to over 4000 RPM. After turning it off, I manually adjusted the pedal, heard the squeak again, and then it started working normally. Occasionally, there's still a noise when pressing the accelerator, but the pedal returns to normal. Does anyone know what might be causing this issue or what might be broken?
