عبدالله علي
2025-01-23 11:42
How can I turn off the maintenance light on my Toyota Camry?
عبد العزيز حارث
عبد العزيز حارث2025-02-06 18:29
Hey there! About your question on how to turn off the maintenance light on your Toyota Camry, it's pretty straightforward! Just make sure your car is in the ON position first. Here’s what you need to do: 1. Start the car but keep the engine in the ON position. 2. Press the 'Settings' button on the dashboard. 3. Use the buttons to navigate to the 'Maintenance' option. 4. Select 'Reset' for the maintenance light. 5. Check if the light is off now. If you run into any trouble, just ask! Good luck!
خليل علي
خليل علي2025-02-04 20:05
Peace be upon you! I just wanted to share my experience turning off the maintenance light on my Toyota Camry. It was super easy, but I struggled a bit at first. Here’s what I did: 1. Started the car without fully turning on the engine. 2. Pressed the 'Settings' button. 3. Navigated to 'Maintenance' and found 'Reset'. 4. Then, I checked and the light was off! It feels great to solve it yourself! If you have more questions, don’t hesitate to ask!
محمد بندك
محمد بندك2025-02-02 21:14
Hey there! If you’re looking to turn off the maintenance light on your Toyota Camry, you've come to the right place! Here are the steps you need to follow: 1. Sit in the driver's seat and make sure all doors are closed. 2. Insert the key into the ignition and turn it to the "ON" position without starting the engine. 3. Quickly press the gas pedal three times. Make sure not to press it more than three times. 4. Turn off the car and then start it again. The maintenance light should be gone now. If it doesn't disappear, you might want to check for any underlying issues with your car. Hope this helps! And if you have any other questions about your ride, feel free to ask! I can share my experiences with car maintenance and modifications, whether it’s a Camry or another model!
نايف طه
نايف طه2025-02-02 21:14
Hey there! To turn off the maintenance light on your Toyota Camry, you can follow these steps: 1. Turn off the engine. 2. Press the "trip meter reset" button on the dashboard. 3. While holding that button, turn on the ignition without starting the engine. 4. Keep holding the button for about 10 seconds until the maintenance light goes off. 5. Release the button and start the engine to check if the light is gone. If that doesn't work, you might want to swing by a certified service center. It's pretty straightforward! If you have any other questions about buying a car or experiences with different models, feel free to ask!
