علي اشرف
علي اشرف
Aug 11
I heard that the fuel consumption of the 4WD petrol version is higher than the 2WD. How much higher is it? Can the 4WD version switch to economy mode to achieve full 2WD?
خالد فريدة
خالد فريدة2024-10-26 19:07
The Comfort mode suspension automatically adjusts, making the ride more comfortable.
حسين عباد
حسين عباد2024-10-23 21:30
You can drive it as a front-wheel drive. It's economical, fuel consumption is okay. If you're not driving aggressively, you won't really notice the difference.
عبد العزيز عمرو
عبد العزيز عمرو2024-08-12 11:07
On the highway, it's pretty much the same. On other roads, it costs a few bucks more per 100 kilometers. I usually drive in comfort mode and occasionally in sport mode, but mostly in comfort all the way. 😁
فهد نعمان
فهد نعمان2024-08-12 09:44
The economic mode is 2WD.
I have a 2014 Korando 2.0 petrol 4WD luxury version. Could you please tell me how often or after how many kilometers I should change the transmission fluid? Thanks!
Why can the T60 Petrol 2.0T Automatic 4WD only upshift but not downshift in manual mode?
How do you switch between the advanced mode and normal mode of the Phaeton's air suspension? In the advanced mode, is the front lower and the rear higher when parked? [Facepalm]
Has anyone converted their T8 2.0 2WD to a 4WD version?
Could you explain how to operate the TRD Pro: the use of 2WD and 4WD, high-speed 4WD and low-speed 4WD, and the scenarios for each terrain mode? What are the functions of each button and their usage scenarios? Thank you.
Hi everyone, for the 2021 Toyota Land Cruiser Prado LTD, how do you switch between high-speed 4WD and low-speed 4WD? When driving in full-time 4WD, do I need to come to a complete stop to switch between high and low-speed 4WD? Thanks!!
Is the GV70's all-wheel drive truly full-time, and what is the front-rear power distribution ratio? I've seen some owners say it's not full-time AWD, mentioning that some modes require manual adjustment to four-wheel drive or allow switching to two-wheel drive. I'm a bit confused. Could someone explain the situation with this AWD system and how to use it?
I have a question for the owners of the 4WD version of this car. Today, I asked a friend if setting the 4WD selector to 2WD on the Outlander Sport makes the fuel consumption the same as the 2WD version. He said no, even if you set it to 2WD, there's still some power loss, and the fuel consumption is higher than the pure 2WD version. Is that true, folks?
Why does the economy mode in the Tanlu need to be set manually every time, and after turning off the engine and restarting, it automatically switches back to the standard mode? It seems like it can't be configured.
Hongqi HS7
Hongqi HS7BHD 16,990 ~ 18,990Gasoline & Petrol
