عاطف حسن
عاطف حسن
Jul 8
I decided to buy the Nissan Kicks because I was looking for a budget-friendly, economical car. Honestly, Nissan has a solid reputation for quality and after-sales service. Among all the Japanese-brand SUVs, the Kicks was the most affordable option I could find. I thought it would be enough for daily use — small engine, fuel-efficient, and family-friendly. But after using it, I realized it's severely underpowered on the highway. If the car is fully loaded with passengers and the AC is on, once you hit 100 km/h, trying to accelerate or overtake becomes almost impossible! My advice: if your budget allows, go for a bigger engine. Don’t underestimate this point. As the saying goes, “Whether you need it or not is one thing — but having it makes all the difference.” Handling & Comfort The car is light and easy to drive in the city. The throttle and brakes are very responsive. Fuel Consumption People often say Japanese cars are fuel-efficient, but that wasn't really the case here. In traffic, fuel consumption reaches around 9 L/100km, and even on highways, it’s about 8 L/100km. I don’t think this car is suitable for long-distance driving. Exterior Design The design is modern and youthful. The front has a sporty look with Nissan’s signature V-Motion grille. The side profile is well-proportioned, and the rear has a nice sporty touch with the floating roof design. I just wish it came in a dual-tone option. Interior & Technology The interior design is simple, but there’s a lot of hard plastic. The 8-inch screen supports Apple CarPlay, voice control, navigation, and remote monitoring — plus 10 years of free basic data, which is a great bonus. Noise Insulation Once you go over 100 km/h, cabin noise becomes very noticeable — to the point where you have to raise your voice to talk. Maintenance & Issues Right after the first service (oil and filter change), the oil warning light came on and the engine shut off right after I left the service center! On the second day after delivery, the battery warning light came on. I thought it was a loose terminal, but even after tightening, the light stayed on. There’s a strange noise from the CVT transmission when starting off. Some people say it’s normal for CVT, but I drove a test unit before and didn’t hear it. The screen froze twice — especially after using voice commands. I had to stop the car and restart it for the screen to function again. Conclusion If you're looking for a budget-friendly city car for short trips, the Kicks might work for you. But if you drive long distances or travel often, I’d recommend looking for something with a more powerful engine and higher build quality. The technical issues, especially with the transmission and infotainment system, make it hard for me to confidently recommend this car.
Does this car have any minor issues? How's the after-sales service? Thanks!
After the discontinuation of the X95, what happens to parts and warranty? How do you handle repairs after the warranty period? Are the parts the same as other cars? Is there a design issue?
I just bought a second-hand car and after driving it for less than 1000 kilometers, it consumed 2.5 liters of engine oil (it's a 5-cylinder car registered in 2014). I'm not sure if any of you experience this oil consumption. Should I switch the engine oil from Shell 0W-40? What should I do, any advice for a budget-friendly solution?
When will this car drop below 100k? I was considering this one and the 5 Series, but ended up with the 5. However, the design of this car is just too stunning. If it goes below 100k, I wouldn't even care about after-sales service, I'd buy one just for the looks.
After cleaning the throttle body yourself, the engine warning light came on. It doesn't affect driving, but how can you resolve this?
First time buying a car and I'm considering the Nissan Kicks and Changan CS35 Plus. How should I choose between these two? Fellow car enthusiasts, which one do you think is better?
I think Volvo's designers haven't seen the interior design of domestic cars. What do you all think?
Where can I buy a suitable air conditioning filter for the Nissan Kicks?
The engine warning light came on after driving over 10,000 kilometers, right when it was time for maintenance. The service station checked and found the gas cap wasn't properly sealed, and they reset the computer. However, the yellow light came back on in less than half a month. The service station is too far away, and I don't have time to go there. Does anyone know what the problem might be? Any help would be appreciated.
Nissan Kicks
Nissan KicksKWD 4,777 ~ 8,131Gasoline & Petrol
