سعود شخبوط
سعود شخبوط
Nov 30
Is the Bluetooth call volume for the Legacy always very low? I've already turned up the car system and volume... still very low... Is it the same for everyone?
Comments( 6 )
نور عبدالرحمن
نور عبدالرحمن2023-09-01 16:43
My 2016 model also has low volume.
محمد كمال
محمد كمال2023-09-01 13:33
I have the same issue. I can't take Bluetooth calls; I can't hear anything at all.
محمد توفيق
محمد توفيق2023-08-30 20:01
Not too bad, I'm using it just fine.
فهد مكرم
فهد مكرم2020-12-02 18:17
I had the same issue before, and later found out that it was because my phone's volume wasn't turned up [facepalm].
أحمد ربيع
أحمد ربيع2020-11-30 16:33
The volume is normal. Try turning up the sound on your phone.
سعود شخبوط
سعود شخبوط2020-11-30 09:18
And also, the sound quality of the Bluetooth connection isn't very good... How can I adjust it? Does anyone know?
Do you experience jerking with your S40? After repairing the oil leak on mine, the low-speed jerking became very severe. I spent 7000 to repair the transmission, but there's still slight jerking. When starting, it jumps to 3000 rpm and then drops to 2000 rpm, with a fuel consumption of 15. I've already spent 10,000, and people say it's an old car, so it's normal. I'm wondering if you guys have experienced this situation!
My E2, with a 47 kWh battery, charges up to 100%, but why does fast charging only add 35 kWh? I've already replaced the power battery due to the same issue, but the problem persists. Please help, it's urgent.
When using Bluetooth to play audio, does anyone else notice the volume is relatively low? With CarPlay and the radio, it feels like setting the volume to 10-12 is enough, but with Bluetooth and AUX, I have to turn it up to 18-20. What's going on here?
I have a 2015 CC, and it's very quiet at idle. But when I hit 70 km/h, the engine noise gets really loud. I'm not sure if it's coming from the engine or the chassis. I have to turn up the music to cover it up. I've already changed the oil in the chassis, but it didn't help. Has anyone else experienced this? Is it normal for a 4WD to be like this?
Hey folks, got a low oil warning and the next day it started making noise. Even after adding 4 liters of oil, it's still the same. Any idea why?
The low-pressure pipe is frozen, and the air conditioner isn't blowing cold air. I've already replaced the expansion valve, condenser, compressor, and left servo motor, but it's still not working. Does anyone have a good solution?
In the morning, when starting the vehicle and driving at low speeds, it occasionally stalls. I've already cleaned the throttle and injectors, but it still stalls sometimes. If the speed picks up, it doesn't stall. What could be the reason? 🤦‍♂️
This car is already six years old. Not sure how many more years it can last, as small issues are increasing and fuel economy is getting worse. The resale value is very low.
Subaru Legacy
Subaru LegacySAR 115,000 ~ 126,500Gasoline & Petrol
