حسين ستار
حسين ستار
Nov 19
Is it true that the next generation of ES will be in 2026? The 2025 model should be the last mid-cycle facelift, right?
حسن عين
حسن عين2024-11-19 23:22
A minor facelift this or next year should lead to a major redesign in the following year.
أحمد حمزة
أحمد حمزة2024-11-19 22:41
The 25 models belong to the seventh generation, second facelift. Next year will be the eighth generation of products.
I bought the mid-range manual model in August 2018, and by March this year, the right side window switch broke. The 4S shop replaced it for free. Now, this switch isn't working again. Do you think I can get another free replacement? It's difficult to find this part on the market, and it's quite expensive online!
Is a 2007 Hyundai Accent, 14,000 km, manual high-end model, with four tires changed last year, insurance expiring in August next year, in good condition, original paint, with minor scratches, expensive for 12,000?
I'm considering buying a Scirocco R. Should I go for the last generation with the EA113 engine or the earlier one with the second-generation EA888 engine?
I've had my car for four and a half years and it's only done 36,000 km. It's a 2019 model with the 4J11 engine. Recently, when I start it cold, the engine struggles a lot. The RPM doesn't go up immediately, and the needle wobbles between 500 and 1000 for a few seconds, making it feel like it's about to stall. Then the RPM suddenly jumps to 2000-3000 before settling back to normal idle after a few seconds. There are no warning lights, and once it's running, everything seems normal. I've cleaned the carbon buildup and throttle, and checked the intake for leaks, but the issue persists. I'm not sure what to check next. What should I look into?
Is it true that you can't open the right middle door when opening the fuel tank cover on the Sharan 2.0 standard model?
If you're looking to get a 2023 facelift model of the X for under 50, do you think it will be possible next year? This year, the market price is around 60.
How much discount can I get on the 2024 BYD Song Plus priced at 13.98? Or should I wait for the 2025 model?
I hope each model from Hongqi can last longer. I'm planning to buy the HS7 48V Mild Hybrid Qixiang Edition before the end of the year. It won't be discontinued by then, right?
Don't rush to buy this car just yet; wait for three to four months as a new model will be released. The 2025 model will come out early next year. People are interested in this car mainly because of its zero fire risk and sincere configuration. Be prepared for the following if you decide to purchase this car: 1. The overall electricity consumption is over 20, and it might be even higher for men driving it, considering the car weighs 2 tons. 2. The car has severe nose diving when you brake, causing it to wobble a few times. 3. The sound insulation is poor; you need to close the doors with force, and dust easily gets inside the car. 4. Repair parts are as expensive as those for Mercedes-Benz and BMW. 5. The seats, while known as "Nissan Big Sofas," are not as comfortable as those in the Sylphy. 6. There are quite a few minor issues and faults, with the car's system being a significant drawback.
Does this damage the primer? Will it rust later? Any knowledgeable brothers or masters here? 😢😢😢 Using a touch-up pen doesn't seem to last long, right? How should I deal with this? 😢
Lexus ES
Lexus ESKWD 16,250 ~ 22,639Gasoline & Hybrid
