عبد العزيز صالح
Nov 17
The 2025 ES300h has replaced its mixed injection with direct fuel injection, and the tires have been changed from 18 inches to 17 inches. This change seems to be a downgrade.
Can the 18-inch tires from the Shanhai Cannon be used on the Maxus T60?
I'm getting ready to change my tires. Has anyone switched to 225/55/17? Are there significant differences in comfort and handling?
4Is it possible to change the tires to 215/60 R17? The 55 ones seem a bit small.
5How many kilometers did you guys change the tires for the 2021 C11 with 20-inch tires? What tires did you switch to? My original ones were Pirelli tires.
6Looking for advice on changing tire and wheel sizes. The original Sahara comes with 245/75/17 ET+44. Considering two options for new wheels and tires: Option A: 265/70/17 ET+18 9J, where the tire is flush with the fender. Option B: 265/70/17 ET 0 8.5J, where the tire slightly protrudes beyond the fender. Which option is better in terms of performance and safety?
7Does anyone know if the 2018 Toyota Land Cruiser with 17-inch rims can be upgraded to 18-inch ones?
8If you want to modify your tires without changing the 17-inch diameter, you can consider changing the tire's width or profile. You can opt for a wider tire for better grip or a different profile for improved performance. Just make sure the new tires fit your vehicle's specifications and don't affect the overall driving experience. It's always a good idea to consult with a professional or refer to your vehicle's manual for recommendations.
9My 2017 model luxury car's original 18-inch tires have nearly 70,000 km on them. I'm looking to replace them with better quiet tires. Any recommendations?
10Consulting everyone, if I change my manual 30 to high-end 18-inch wheels, do I need to modify the brake discs and calipers?
