أحمد جواد
أحمد جواد
Nov 18
I bought the M8 Master Super Hybrid car, but I can't tune into the local county-level city radio stations. Can someone help me out? Thanks!
حسن ياسر
حسن ياسر2024-11-24 21:28
The Master Hybrid lands at 235,000. [Grin]
حسن عبد القادر
حسن عبد القادر2024-11-24 19:40
How does this car drive?
خالد فاروق
خالد فاروق2024-11-22 17:29
How many meters is your ground clearance?
I bought my Hyundai Reina at the end of 2017, and it's been almost 4 years. Since January 2021, I've noticed that the front left wheel pulls to the left. When I let go of the steering wheel, it veers to the left! Can someone explain this? 😊
I bought the lowest trim of the automatic model. Is there a similar version? I want to ask if the trunk comes with a storage board. My car didn't come with one, and they said only the higher trims have it. Can someone explain this?
This car is overall okay, but the manual transmission clutch isn't very user-friendly. I bought my car in 2020, and it's run 23,000 kilometers. In the city, where the clutch is used frequently, it gets harder the more I press it. Do any of you guys have this issue?
I bought a 2007 1.6 automatic luxury model for 16,000 in 2022. It was noisy and not easy to drive, so I ended up spending 12,000 on it gradually. I replaced the shock absorbers, engine mounts, stabilizer bar, light bulbs, bearings, and cleaned the engine—pretty much everything that needed fixing. It's much better to drive now and feels like it can last a few more years. I have to say, the parts are really cheap. The city fuel consumption averages 8.8, and I drive pretty aggressively.
I just received the news that the local 4S shop has closed. I want to ask, for car owners without a local 4S shop, how do you handle regular maintenance? Do you have to go to another city for the 15 maintenance services over the 5 years for a new car?
Hey guys, my Levante's trunk lifts up just a bit (2cm) and then stops. If I manually lift it a bit more (5cm) and then use the key, it works again. It's really frustrating because the door is super heavy. Hoping someone knowledgeable can help me out. 😢
How long is the warranty for BYD charging stations? I recently bought a BYD electric vehicle. A few days ago, the charging tripped after just half an hour. After resetting, it tripped again after about 20 minutes. I didn't pay much attention at the time. Today, while charging, it didn't trip the circuit breaker within ten minutes, but it stopped charging and there's no power. I don't know the reason. If anyone has had a similar experience, please advise!
Hi car enthusiasts! I'm a newbie when it comes to cars 🥺. Is there an SUV available within 70,000 to 80,000 RMB that's good value for money? I need it for commuting, across city areas, and a hybrid would be even better 🧐. Really looking for recommendations.
I just bought a new Highlander less than two years ago, and now I'm thinking about switching to the new Prado. Are there any other owners with the same thought? I'm not sure how this car is, mainly for city and highway driving. I'm torn. 😖
Hey everyone, quick question: When I bought the Toyota Levin Hybrid, the dealership offered a lifetime warranty on the power battery. Will not getting maintenance done at the dealership affect this lifetime warranty?
GAC M8
GAC M8SAR 129,540 ~ 183,870Gasoline
