سلمان أمينة
2019-10-26 06:41
The engine warning light is on, indicating the air-fuel mixture is too rich.
سلمان أمينة
سلمان أمينة2019-10-28 17:16
I replaced the post-oxygen sensor with the NTK brand, and for now, it's not showing any lights.
فهد تامر
فهد تامر2019-10-26 06:53
If the 4S shop or the mechanic finds that the air-fuel mixture is too rich, you need to check if there's an issue with the air flow sensor.
عبد العزيز خديجة
عبد العزيز خديجة2019-10-26 06:48
If the check engine light comes on, it usually indicates an issue with the engine's electronic control system. If the error code reads that the mixture is too rich, it could generally be a blockage in the intake duct or a faulty air flow meter.
Mazda Mazda 3 Sedan
Mazda 3 SedanAED 76,542 ~ 96,000Gasoline
