علي حازم
علي حازم
Oct 23
Has anyone added electric side steps to their Tank 300 4WD? Could you share some pictures or videos for us to check out?
حسن حارثي
حسن حارثي2024-10-28 23:33
I will wait for a couple of days. Once the car arrives, I'll take a photo for you.
If you are experiencing an issue with your Mitsubishi Galant where holding the lock button causes the yellow light to come on and the window control buttons become unresponsive, here are a few steps you can try: 1. **Reset the System**: Sometimes, simply turning off the car and restarting it can reset the electronic systems, including the window controls. 2. **Check the Fuses**: Locate the fuse box and check if any of the fuses related to the power windows or central locking system are blown. Replace any blown fuses with the correct type and rating. 3. **Inspect the Battery**: Ensure that your car battery is not low on charge, as insufficient power can cause electronic systems to malfunction. 4. **Consult the Manual**: Refer to your vehicle's owner manual for any specific troubleshooting steps related to the power windows and central locking system. 5. **Visit a Technician**: If none of the above steps work, it might be best to consult a professional mechanic or visit a Mitsubishi service center to diagnose and fix the issue. Please do not attempt to fix any electrical issues if you're not familiar with car electronics, as it might lead to further damage.
I went to check out the Lavida Pure Electric with a 346 km range today. The salesperson said the original price was over 140,000 RMB, but after the discount, it's 85,800 RMB. However, they also mentioned an additional charge of 3,000 RMB for the charging station and a combined fee of 2,000 RMB for licensing and service. But SAIC Volkswagen's official customer service said the charging station is supposed to be free. [Shocked] This is quite a trick.
I'm curious if it's due to my driving habits? [Facepalm] Why is the fuel consumption of my NC quite different from what many people say? I feel like it's more than 10 liters per 100 kilometers. Some drivers can go 600 kilometers on a full tank, but with 100 kilometers on the highway, I only managed just over 300 with three-quarters of a tank. I spent 274 RMB on fuel, which works out to 11 liters per 100 kilometers. (Or is it because I used 92-octane fuel, haha?)
Dear car enthusiasts, has anyone added a catalytic converter cleaner to the fuel tank of a 2011 manual Touran? After I added this kind of cleaner, it started emitting white smoke and the check engine light came on. Has anyone experienced this situation?
Today, when I went to check out the Porsche 718 and Mercedes E-Coupe, the Porsche salesperson recommended a nearly new Porsche Taycan to me. Do you guys recommend it? My family has never had an electric car, but I'm young and really like two-door sports cars. I'm not sure what to choose.
Hi everyone, I'm looking for a good dashcam specifically for the Alphard. I've checked out Hikvision and Papago so far. Do you have any recommendations or experiences to share?
After 8 years with my old petrol car, it started burning oil, and I noticed a lot of people around me were switching to electric vehicles. That got me thinking. I was originally planning to get the top-spec Tank 300 (Menglong), and during the National Day holiday I went for a test drive — it met my expectations.On the way back, I stopped by a Jetour dealership and saw the T2. My daughter instantly fell in love with the exterior and interior — it completely overshadowed the Menglong in her eyes. Looks clearly played a big role, and after a test drive, it felt good enough. Since I don’t really need 4WD for daily driving, I booked it right away. Looking back now, I do wish I had waited for the 4WD version — a bit more power would’ve been nice.For this type of vehicle, electric power saves a lot. For daily use, my cost is just around 0.10 AED/km (charging at home on off-peak rates of 3.3 AED/kWh). My daily round-trip to work is under 20 km, so I only charge every four days, when the battery hits around 20%.For long-distance trips, I don’t bother with charging — it’s too much hassle. I just set the car to preserve 60% battery and drive on petrol. Even if fuel consumption is slightly higher, it’s fine since I only do a few road trips per year.The car is heavy and feels solid on the road. Acceleration is decent, but the 4WD version definitely would’ve offered better power and confidence. I’ve had the car for over half a year now. So far, the only issue has been a slight noise from the steering system — which was fixed. Other than that, no major problems. Buying a car always involves a bit of luck anyway.The biggest downside is the driver assistance system — it lags behind the competition. The infotainment system has improved a bit with the latest 4.11 update, but it still has room for improvement.Overall, I’m quite satisfied. Compared to many newer EV startups, Chery is an established brand. The lifetime warranty adds a lot of peace of mind, especially on the powertrain and electric components.
Nissan Pathfinder
Nissan PathfinderQAR 123,000 ~ 230,000Gasoline & Petrol
