avatar-image
خالد جليل
Oct 14
How can I permanently disable the start-stop system on a Tank? Every time I turn off the engine and restart, I have to disable it again.
عمر إدريسي
عمر إدريسي2024-10-16 01:34
The driving mode defaults to automatic. It seems like the air circulation defaults to internal circulation. After turning off the engine and starting it again, it resets to the default settings.
حسين طلحة
حسين طلحة2024-10-15 10:17
Look for introductions on TikTok.
علي فادي
علي فادي2024-10-14 11:18
Buy a Start-Stop device (I want some peace)
The battery is new, and the car starts fine when it's cold. But after driving for about ten minutes, sometimes when I stop and try to restart, it makes a squeaking sound and won't start. If I turn it off and then gently start it again, it works. I'm asking if anyone knows what might be causing this issue and if anyone has experienced something similar?
How can I turn off the automatic MP3 advertisement that plays every time I start my Hongqi H7?
Can the start-stop system be disabled by reprogramming on the 2016 Vitara?
How do I turn off the auto start-stop on the ILX? 😅
How do I turn off the engine start-stop system?
How do I disable the automatic start-stop function on the 2016 Peugeot 508, guys? Every time I start the car, I have to manually turn it off.
Does the ambient light in your Haval turn off by itself? In my car, every time I connect the Bluetooth music to my phone, I have to turn it on again when I start the car. It always turns off by itself.
Could someone advise how to disable the courtesy seat function on the Aerial? It's really annoying to use every day, and I've checked every setting but can't find where to turn it off.
Gear won't engage. Every time this happens, I just turn off the car, wait a bit, then restart, and it goes back to normal. Took it to the repair shop, but they couldn't find any issues.
When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
Nissan Nissan Pathfinder
Nissan PathfinderAED 158,000 ~ 220,797Gasoline
