عبد العزيز حمدان
عبد العزيز حمدان
Nov 25
Can the spray angle of the washer nozzles on a 408 be adjusted? When I use it, it sprays water onto the roof and the rear of the car. If there's dust on the body, it looks terrible. Plus, if there's a car close behind, it might get sprayed as well.
سلمان رمضان
سلمان رمضان2024-11-29 21:31
Can't adjust it, just tap it.
نايف زيلاخ
نايف زيلاخ2024-11-25 18:51
I haven't adjusted it before, but you can lightly pull the lever, it's very light. If you pull a bit harder, it sprays onto the rear glass. [I need some quiet][I need some quiet][I need some quiet]
عبدالله حبيب
عبدالله حبيب2024-11-25 10:36
Modify it yourself [Grin][Grin]
علي قنصوح
علي قنصوح2024-11-25 09:56
The 2022 model can't be adjusted, and there's a good chance the 2024 model can't be either. 😬
Where is the rear glass washer nozzle? It always drips down instead of spraying upwards. 🤔
What could cause the 2014 Peugeot 308 to not spray windshield washer fluid? Is it the lever on the right side of the steering wheel that needs to be lifted forward for a few seconds? I can't find the spray nozzles, so I'm considering using a needle to check if they're clogged. Any advice from the experts?
Ride Comfort: The car feels very stable at high speeds, which gives you a real sense of safety — especially thanks to the solid chassis. However, the seats are a bit firm, and on long trips, they can start to get uncomfortable. Fuel Range: On a full tank, I’ve managed around 650 km on the highway. In summer, or when the car is fully loaded with the A/C running, that drops to about 500 km. In the city, I usually get around 400 km per tank. With current fuel prices (I always fill up with 95), it basically costs me around AED 1 per kilometer. Performance: This is the part I really want to talk about — and complain a bit. With ECO mode turned off, the initial power off the line is decent, but that’s about it. Once you get moving, the car starts to feel like it’s struggling — like a small engine pulling a heavy body. If you don’t mind the loud engine noise, you might get a bit of excitement, but realistically, you’re running close to 4000 RPM for that. Overtaking at 120 km/h is tough; the acceleration just doesn’t keep up, and it feels risky. That said, I have to give credit to the car’s off-road capabilities — it handles rough or muddy roads surprisingly well and won’t leave you stuck.
Peugeot 408
Peugeot 408AED 114,900 ~ 150,000Gasoline & Petrol
