نايف خديجة
نايف خديجة
Nov 24
Have you ever experienced your car stalling suddenly while turning, then after waiting a bit, it starts again? I suspect it might be due to bad fuel quality. I usually fuel up at a fixed station, but this time I went to a different one, and shortly after, this issue occurred. It never happened before. Have you guys encountered this situation? What could be the cause? My car is a 2020 1.6T Anniversary Edition.
سلمان رمضان
سلمان رمضان2024-11-29 21:35
Try switching back and see if it's the fuel issue. Maybe the two major oil brands are more reliable.
حسن عين
حسن عين2024-11-25 00:15
Go to the 4S shop for a check-up.
Recently, my fuel consumption has suddenly increased significantly. I suspect it might be the carbon canister purge valve. How should I check it? Can any experts help out?
Hey folks, I need some advice. When I start the car and turn on the AC, there's this really bad smell at first, but it goes away after a bit. How can I fix this? Thanks!
Why does my Sunny manual stall frequently with jerking? I never had this issue before with a manual. Could it be that the clutch needs replacing?
Are there any 18-year Honda City owners here? Could you take a picture of your car's battery? After my car was repaired outside, it wouldn't start after a few days. I suspect the shop might have swapped my battery.
2018 model, two-door F56, there is a continuous and noticeable thumping sound from the right rear of the vehicle at idle. I've checked it myself, and when I unscrew the fuel cap, the sound stops immediately. Once I put it back on, it starts again after a while. If I cover the fuel cap with my hand, the sound stops right away, but once I remove my hand, it starts again. I suspect it has something to do with a component related to the fuel tank, perhaps the charcoal canister or the fuel tank vent? Anyone knowledgeable can help? I feel like I'm close to solving the problem, can someone assist?
I bought a second-hand 2011 manual 2.0 GL. According to the specs, the fuel tank is supposed to be 65 liters, but the most I've ever filled is around 48 liters, even after the fuel light came on and I drove another 60-70 kilometers. What's going on here?
Has anyone ever modified their ACC after getting their car? I want to ask how effective it is.
Hey fellow car enthusiasts, why does Bluetooth never connect automatically? I always have to connect it manually, and even though the phone function works fine after connecting, I can't hear WeChat voice messages.
Help needed, fellow Peugeot owners! Ever since my little Peugeot went on a continuous uphill drive for over an hour a few days ago, it's been having issues. The RPMs go up, but the speed doesn't. It's not too bad when not on the highway, as pressing the accelerator quickly gets the RPMs and speed up. But once I'm on the highway and going over 80-90 km/h, I need to press the gas to at least 2000 RPMs for the speed to increase very slowly. On inclines, if I don't reach 2500 RPMs, the speed drops. I never had to go over 2000 RPMs on the highway before. What's going on? 🌹
I drive a 1.6T 508, and it's been 8 years with 85,000 kilometers on it. Recently, after I filled up with some cheaper gasoline, I've been noticing this humming sound when I drive faster. It's coming from the engine, and it's making me feel dizzy. Not sure if it's just in my head.
Peugeot 408
Peugeot 408KWD 5,800 ~ 12,600Gasoline & Petrol
