How many loudspeakers does the 2020 model 408 actually have? Can someone clarify? I've seen some people say there are 2, and some say there's 1. My loudspeaker is a bit muffled lately, so I'm planning to buy and replace it myself. If anyone has done this themselves, please let me know [pray]. (I saw one on the driver's side, but there's too much stuff on the other side to see clearly.)
The engine number for a Jeep Liberty is typically located on the engine block. You might find it on the side of the engine, near the oil filter, or on the front of the engine, depending on the model year. It's usually stamped into the metal, so it might require some cleaning to see it clearly.
Is the GV70's all-wheel drive truly full-time, and what is the front-rear power distribution ratio? I've seen some owners say it's not full-time AWD, mentioning that some modes require manual adjustment to four-wheel drive or allow switching to two-wheel drive. I'm a bit confused. Could someone explain the situation with this AWD system and how to use it?
4I've always wanted to switch to the 86 since it’s my third car after getting my license, but after trying it, I have some regrets. The interior, sound insulation, and loudspeakers of my previous German cars make me hesitate about the 86. Since I drive half on the highway and half in the city, I’d like to know everyone's honest daily driving experience. Let's set aside its excellent handling and looks, and just talk about daily driving comfort.
5I saw a video on TikTok about the Genesis 4S, saying the new model will switch to a 2.5T engine. Why haven't I seen the 2.5T?
