محمد علياء
محمد علياء
Dec 13
What causes the 2021 Toyota RAV4 to make a "ding" sound at the moment of ignition? Sometimes it makes the sound, and sometimes it doesn't.
Toyota Yizhi, the air conditioning sometimes cools and sometimes doesn't. Pressing the AC button doesn't seem to help. Not sure what's going on.
What could be causing the engine to make a ticking sound?
The loudspeakers in my RDX are making a popping sound and sometimes they fail. Previously, there was an occasional popping sound when starting the car cold, but recently it happens every time I start the car. The car's Bluetooth seems to be working fine, and the screen shows that music is playing, but there's no sound. Sometimes restarting the car fixes it, but sometimes it doesn't. This is happening more frequently now. Has anyone else experienced this? What could be the issue?
When you warm up your car or are idling at a red light, can you hear a "tatata" sound inside the car? Sometimes it's there, sometimes it's not. It's not the engine sound. Even if you press the accelerator a bit, the "tatata" sound frequency stays the same. Not sure what's causing it.
Hi, what could be causing the steering wheel to make a buzzing sound when turning?
Does your 5-door Artist make a slight humming sound from the rear seats after ignition?
Why does my 2021 manual Santana sometimes have no response when I try to start it, requiring several attempts to ignite?
Hey car enthusiasts, my car sometimes makes a humming noise when turning. Does anyone know what might be causing this?
How can I adjust the seatbelt warning sound on the 2021 Toyota Asia Lion Elite? The sound is too loud, how can I make it quieter?
Is it a problem with the ignition switch if the Volvo S40 key is turned to the second position, but there's no power and it reports an engine anti-theft system fault? I changed the ignition switch, and now it's sometimes good and sometimes bad. Sometimes the dashboard lights up, sometimes it doesn't, and sometimes it even starts automatically.
Toyota RAV4
Toyota RAV4AED 97,976 ~ 152,900Gasoline & Hybrid
