أحمد عل
2024-11-20 16:25
Is it normal for the air conditioner to make a loud noise when heating? When the car is not running, the sound is quite loud, like a fuel car engine [cover face]. Is there a problem that needs to be checked? It's a 2025 model.
فهد جعفر
فهد جعفر2024-11-22 10:34
Isn't it too loud? Are you running the fan speed too high?
محمد إسحاق
محمد إسحاق2024-11-21 07:43
Just don't listen outside [Grin]
عبد العزيز خليل
عبد العزيز خليل2024-11-20 16:56
Mine too...
How many liters per 100 kilometers does the fuel consumption increase when using the air conditioner in the city during the summer?
Is it normal for a loud humming noise, similar to an air conditioner compressor, to come from the front of the car during charging?
Do you hear a humming sound on levels 1-3 when you turn on the air conditioner/fan? How can this be fixed?
Hey fellow car enthusiasts, I've heard that the T8's engine noise inside the car is quite loud when it's running. How bad is it, and is it tolerable?
When the self-drying function of the unit's air conditioner is activated, will it start after locking the car regardless of whether you turn off the air conditioner before turning off the engine or just turn off the engine and leave the car directly?
When the RPM reaches 2800, there's a loud roaring noise, but after 3000 RPM it disappears. What's going on? [Cover face]
I have a 2018 V40, and when I start it, the steering wheel and the center console panel shake a lot, especially when I turn on the air conditioning. It's only run about 50,000 kilometers. It takes quite a while for the shaking to reduce. What could be the problem? Has anyone else experienced this?
Will running the air conditioner on a Kia Seltos for 2 hours while stationary damage the car? I've heard that the manual says idling is bad for the car?
Is there anyone else experiencing a buzzing noise when the air conditioner is on fan mode?
Is the air conditioning in your cars cool enough at noon when it's 38 degrees? I'm about to melt from the heat.
BYD BYD Seal
BYD SealAED 149,900 ~ 170,000Electric
