أحمد عبدله
Dec 1
What type of disc does the 2012 Sharan CD player use? I've bought from several places, and they all show playback errors.
I have a 2017 1.4T with all-wheel drive, driven over 60,000 kilometers in 5 years. When I accelerate to 60-80 km/h, there's a severe jerking, and it's slightly noticeable around 110 km/h too. I've changed the spark plugs and transmission fluid, and checked the engine mounts, but it hasn't helped. No error codes are showing up. Anyone else experiencing this issue? It's really frustrating to drive like this. I've been to several repair shops, even the dealership, and they suggested taking apart the transmission for inspection. 😖😖
Could anyone tell me how to use the CDC changer in the car? The changer shows multiple CD slots, but where do I insert these discs?
