عبدالرحمن نور
عبدالرحمن نور
Nov 10
Hey fellow drivers, are paddle shifters useful? How should I drive on a 10km downhill? I usually just stay in D gear and occasionally press the brakes.
أحمد باسل
أحمد باسل2024-11-11 11:09
Switch to sport mode, then use the paddles to shift up or down, and you'll be able to lock the gear.
حسين كامل
حسين كامل2024-11-11 09:26
Starting, chassis, oil, downshift [I want to be alone]
علي ماجد
علي ماجد2024-11-10 22:19
It generally isn't needed if you're not driving in mountainous areas. In automatic mode, if you tap the left paddle, it will downshift by one gear. The dashboard will display "D" followed by a number, which indicates the current gear.
نايف حسن
نايف حسن2024-11-10 19:53
On a ten-kilometer downhill, you can use the paddle shifters to switch to manual mode and use the engine to slow down. If you keep using the D gear and constantly apply the brakes, the brake pads might overheat and wear out.
The gear shift light for the 150 isn't on. Could it be because a button wasn't pressed, like the ones for P, R, D?
When the car is in D gear at idle, it feels weak (like an ant crawling), but when you press the accelerator, it becomes normal. In reverse gear, it doesn't move at all unless you press the accelerator. The car is a 2016 Haima S5.
When going downhill in a Yizhi and pressing the brakes, the RPM automatically increases, which is really annoying. Is there a way to adjust this? Do any fellow car enthusiasts have a solution?
The gear lever on this company car is problematic. After shifting to reverse, the detent stays in the engaged position even when you return it to neutral. You have to push it down to disengage. I didn't pay attention today, and when coasting downhill while pressing the clutch, I directly shifted to first gear without pushing the detent down. As a result, the car stalled and now it won't start at all.
The gear shifting feels jerky. When going downhill, just a tap on the brake slows it down to the minimum speed. The fuel consumption is too high, basically 11 liters in the city.
My One suddenly won't move when I press the gas while in D gear today. It feels like something is dragging it. Any fellow car enthusiasts know or have encountered this situation before?
Hey car enthusiasts, quick question. When I switch from N to D while idling and press the brake, the car jerks a bit. It's a new car, is this normal?
When you shift to D gear and press the accelerator to start, does your car make a buzzing sound, like exhaust resonance?
Hyundai Sonata
Hyundai SonataOMR 10,450 ~ 13,150Gasoline & Hybrid
