علي هاماوي
علي هاماوي
Feb 15
The timing belt in a Kia Sportage engine typically needs to be replaced every 60,000 to 100,000 kilometers. However, it's always best to check the owner's manual or consult with a professional mechanic for the most accurate maintenance schedule for your specific vehicle model.
محمد قيس
محمد قيس2024-11-11 00:14
I changed mine at 140,000 km, and the belt I replaced still looked pretty good.
عمر سامر
عمر سامر2024-04-03 01:15
It's safer to replace it at seventy to eighty thousand kilometers.
فهد حمزة
فهد حمزة2024-02-28 21:25
Around 100,000 kilometers.
To purchase a McLaren P1, there aren't specific conditions like Ferrari's rule where you need to own another Ferrari model to buy an Enzo. However, McLaren may have certain requirements or preferences for their customers, such as a history of owning other McLaren models or being a part of their exclusive clientele. It's best to contact a McLaren dealership directly to get the most accurate information regarding purchase conditions.
The engine number for the Peugeot RCZ is typically located on the engine block. You might find it near the engine's front or side, often engraved or stamped on a flat surface. It's best to consult the vehicle's manual or contact a Peugeot service center for precise information.
The 2018 Rolls-Royce Ghost Extended Wheelbase, with 12,000 kilometers driven and having been impounded by the court for nearly three years, would have its value affected by several factors. These include its condition after being impounded, market demand, and any depreciation over time. For an accurate valuation, I would recommend consulting with a professional appraiser or checking the current market listings for similar models.
You can consider upgrading the wheels on your Subaru Liberty Wagon to a larger size to prevent scraping against the chassis and front end. Typically, people upgrade to 17 or 18-inch wheels for better clearance and aesthetics. However, make sure to check for compatibility with your vehicle's suspension and wheel well space, and consult with a professional to ensure safety and performance.
If you're considering switching to a Model X, the delivery time can vary depending on your location and the specific configuration you choose. Typically, it might take a few weeks to a few months for delivery. It's best to check directly with Tesla for the most accurate and up-to-date delivery estimates.
The 2015 Volkswagen Touran with an automatic transmission uses a timing belt. It is typically recommended to replace the timing belt every 60,000 to 100,000 kilometers, depending on the manufacturer’s specifications and driving conditions. Always refer to the vehicle's manual or consult with a professional mechanic for the most accurate information.
The sound of rustling near the throttle belt on a 10-year-old Alto could be due to several reasons. It might be caused by a worn-out or loose belt, debris stuck in the belt area, or possibly an issue with the belt tensioner. It would be best to have it inspected by a professional to determine the exact cause.
When the MINI is in D gear and you brake, if there's a prompt to shift the transmission to P gear, there might be a couple of reasons for this. It could be an issue with the gearbox or a safety feature that's activating. If the car doesn't move when you release the brake, it might be due to a malfunction or an electronic system engaging to prevent movement. It's best to consult the vehicle's manual or contact a professional mechanic to diagnose the issue accurately.
If you're planning to replace the LED lights on a 2013 Kia Sportage yourself, you'll need to know the specific model of the LED lights required. It’s best to consult the vehicle's manual or check the existing LED bulbs for their specifications.
Kia Sportage
Kia SportageAED 77,000 ~ 113,500Gasoline & Petrol
