Tire pressure issue: I mainly didn't understand it. It says if there are fewer than 3 people, set it to 2.3, and if there are more than 4 people, set it to 3.0. Not sure if I understood it correctly.
Hi everyone, is the electric current noise inside the McLaren GT really loud? I test drove it the other day, and at first, I didn't hear it, but later as I sat in the passenger seat, I seemed to hear a bit. I've seen many people say the noise is quite loud and can't be fixed... I'm a bit OCD, and constant noise would drive me crazy. I'm now hesitating about buying this car.
4If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
5Guys, many people are saying that the GV80 has issues with bumpy roads and uneven surfaces. Is this true? How can we go on road trips then? Could it be a problem with their mode settings or the electromagnetic suspension?
6To reset the oil light on an Acura RDX, follow these steps: 1. Turn the ignition to the "ON" position, but don't start the engine. 2. Use the steering wheel buttons to find the "Settings" menu on the display. 3. Navigate to "Maintenance Info" or "Oil Life" using the arrow buttons. 4. Press and hold the "Reset" or "Select/Reset" button until the oil life resets to 100%. Make sure to consult your vehicle's owner's manual for any model-specific instructions.
7I just bought a new Highlander less than two years ago, and now I'm thinking about switching to the new Prado. Are there any other owners with the same thought? I'm not sure how this car is, mainly for city and highway driving. I'm torn. 😖
8Touareg 3.0, after over 20,000 km, experiencing differential resonance when turning. The dealer isn't resolving it, saying it's a design flaw. The differential is smaller than before. Changing the differential oil can temporarily fix it, but the resonance returns after another 20,000-30,000 km. Do you guys have this resonance issue with your cars?
9Didn't they say this car was discontinued? Why are there still a few hundred sales every month, just going steady? Aren't people worried about after-sales issues?
10In the past couple of months, I've experienced my car's system crashing twice. The first time, I had to disconnect the car battery and reset to factory settings to get it back to normal. But after about ten days, it happened again. This time, I didn't do anything, and after letting the car sit for an hour, it started working fine again. I'm not sure if it's a hardware or software issue, as I haven't updated the system for quite some time. Has anyone else experienced something similar?
