Can I replace the battery with a larger capacity one? Has anyone done this? How large can it be? I read online that as long as there's enough space, you can switch to a larger capacity.
When will the HiPhi X switch to 120 and 160-degree batteries? I'm planning to wait for the battery upgrade before purchasing. Will the upgrade lead to a price increase? How long does it usually take to get the car delivered?
For a 2018 Model S 100D with 80,000-90,000 kilometers, the remaining battery range can be significantly different compared to a 2022 Model 3 or Model Y with a 78 kWh battery. The older Model S may experience some battery degradation over time, affecting its range. When considering a used car, it's understandable to be concerned about the battery's performance and capacity.
Hi friends, how long can your X70P battery last on standby when fully charged?
4You can consider upgrading the wheels on your Subaru Liberty Wagon to a larger size to prevent scraping against the chassis and front end. Typically, people upgrade to 17 or 18-inch wheels for better clearance and aesthetics. However, make sure to check for compatibility with your vehicle's suspension and wheel well space, and consult with a professional to ensure safety and performance.
5Does the Model X have a 2019 Standard Range version? Is the suspension the new version? Apart from battery capacity, what are the differences compared to the 2019 Long Range version?
6Hey fellow car enthusiasts, the front reading light switch is broken, specifically the button inside the circuit panel. Does anyone know where I can get it replaced or which model I should buy?
7Dear fellow car owners, is it necessary to do full car sound insulation for the Vito if it's primarily used for family and for its large space, and only goes on the highway less than 5 times a year? Also, how can I modify the interior for better cost-effectiveness for family use?
8What is the battery model for the oldest version of the Haval H2? Can someone take a photo? I want to buy a battery online, but the car is not with me.
9Hey car enthusiasts, how long have you been driving the Santana with the Aisin 6AT automatic transmission? Is it prone to issues? I've read online that it might have noise issues and jerking between 3rd and 4th gear. Is this transmission really durable?
10Can the 2016 imported Outlander be disconnected from power for a long time? I saw online that it might cause data loss.
