علي اشرف
علي اشرف
Nov 18
I've looked at a few models and feel that the exterior of the VW Teramont is quite impressive. However, I immediately gave up on it when I saw its small gear shift. It seems that the VW Teramont, Talagon, and Tayron all have this small gear shift. I believe that if they changed it to a regular-sized gear shift, more people would choose these models, right?
عبدالله عوادة
عبدالله عوادة2024-11-20 23:59
From the information I found, the gear design of Volkswagen models like the Teramont, Lamando, and Talagon is relatively standard and practical. There's no evidence suggesting they have "stingy" gear designs. Therefore, even if the gear design were changed, it's unlikely to significantly influence consumer choice.
Hey guys, where's the AUX port on the 14 or 15 model? I saw that it comes with AUX in the specs.
What could be the reason for a Haima S5, 2016 model Enjoy Edition, not moving after shifting gears without accelerating?
Is the 2022 GA6 experiencing jerking when shifting from second to third gear and also when accelerating at low speeds in third gear a common issue for this model?
I want to ask if there is any jerkiness when shifting gears in the GA6.
Car enthusiasts: Sometimes when driving a small car, the D gear won't shift up. The RPM suddenly goes up, but the gear doesn't match. What could be the reason?
Are there any T-Cross owners here? Is your car shifting smoothly? I feel like my gear shifts are quite slow.
Before driving, I can only shift gears by pressing the shift lock button, and once I shift back to the P gear, I have to press the lock button again to shift! The brake lights are working fine! I recently replaced the handbrake cable and gear cable. Has anyone else experienced this situation?
Where can I find a 2023 model with a black exterior and red interior in stock?
How do I shift gears when driving a Setus down a long slope?
Volkswagen Teramont
Volkswagen TeramontEGP 2,176,059 ~ 2,938,316Gasoline & Petrol
