سعود لقمان
سعود لقمان
Nov 21
What running boards is everyone using? I initially didn't want to install them, but after a week of driving, I keep scraping my backside every time I get in. It's almost worn out, and I can't take it anymore.
Comments( 11 )
علي عبد الوهاب
علي عبد الوهاب2024-11-26 15:51
On Taobao or Pinduoduo, you can find one with decent sales for around 2000. I got one from Pinduoduo for 1800.
طائي خالد
طائي خالد2024-11-26 14:19
I rarely use it. If you hold down the hazard light switch, it turns off after a while.
خالد طه
خالد طه2024-11-26 14:08
I received electric running boards from the 4S dealership. They mentioned that the original motors are small and prone to issues.
محملة فهد
محملة فهد2024-11-26 11:31
The original manufacturer's car I chose now makes a creaking noise every time I open the door to get in or out. I've contacted customer service, but there's been no resolution. It's really frustrating.
حسن باسم
حسن باسم2024-11-25 21:52
Don't pretend, your pants are suffering [I want some peace].
علي محملة
علي محملة2024-11-24 20:56
Don't add the running boards. If you do, my angel wings will be reduced to just one feather.
فهد ابيض
فهد ابيض2024-11-22 11:52
Without electric steps, getting in and out is a bit inconvenient, especially for the elderly. The electric steps, motor, brackets, etc., can be troublesome if sand and stones get stuck after installation. Each has its benefits.
خالد فريدة
خالد فريدة2024-11-22 00:11
Choosing the right e-bike is crucial. If you don't, the motor noise can be really annoying.
20
أحمد سالم
أحمد سالم2024-11-21 11:21
This thing must have either a fixed or electric one. When I bought the car, I insisted on getting an electric step as a gift. 😁
نايف بارزاني
نايف بارزاني2024-11-21 09:39
I bought the GWM parts on Taobao.
I bought the lowest trim of the automatic model. Is there a similar version? I want to ask if the trunk comes with a storage board. My car didn't come with one, and they said only the higher trims have it. Can someone explain this?
Does the Grand Cherokee look good with fixed running boards? The dealership offered me fixed running boards, but I haven't installed them yet. Does anyone have photos of the Grand Cherokee with fixed running boards?
I feel like the brakes on the McLaren GT are really stiff. Is it possible to modify them later to make them softer? [Facepalm] After being stuck in traffic for half an hour, my right leg is sore. Also, how do you judge the distance on both sides of such a wide car? Every time I drive on narrow roads, I'm terrified of scratching it...
I'm new to cars. Last night, I didn't see clearly while turning and scraped against a pile of sand and stones. Three-quarters of the left side skirt is scratched, and there are one or two scratches on the front and rear doors [facepalm]. Any advice from the experts on how to handle this?
My Jietu X70 has run 30,000 km, and when I cold start it, the idle is unstable, and the car shakes. After about ten seconds, it gets back to normal. There's no error displayed. I left it at the 4S shop for a week, and they cleaned the throttle, carbon buildup, and fuel injectors, but it didn't help. The 4S guys said it might be the fuel, so I switched gas stations, but there's still no change. Has anyone else experienced this? How did you solve it? Please let me know. 🙏
I did the first maintenance at 3,800 km in half a year, and now it's almost a year with only 6,500 km. The 4S shop notified me for maintenance again. Does everyone do maintenance every six months?
Why do my Ariya tires need to be inflated every week? All four tires are losing air. I inflated them to 270 kPa, but after a week, they're only at 250-260 kPa.
Yesterday, I went for the three-year warranty and maintenance. The after-sales service suggested I change my tires, saying the treads are almost worn out. I've driven 56,000 kilometers. How many kilometers did everyone else change their tires at? Has anyone switched to different tires? Continental is really too expensive for me. Are there any high cost-performance alternatives?
Hey guys, the 4S shop is charging 138 for the air filter and 88 for the cabin filter. I didn't buy them. What brand should I go for? Or should I stick with the 4S shop's original filters? I'm hesitant to buy online, worried about fake products.
Volkswagen Teramont
Volkswagen TeramontAED 137,100 ~ 250,000Gasoline & Petrol
