When you activate the remote heating, it automatically turns on the air conditioning, blowing cool air and directing it at the windshield. Previously, it used to maintain the same settings as before the engine was turned off. But now, no matter what you do, it always switches to automatic air conditioning. What's going on? When the vehicle starts normally, the air conditioning works fine. This issue only happens during remote heating.
The rear air conditioning vents are not blowing cold air?
How to turn off the automatic air conditioning?
Can the C40 remotely turn on the air conditioning?
4The air conditioning in the 2011 Kia Sportage has cool air but isn't cooling effectively. What could be the reason?
5Why isn't the air conditioning in my Alto cooling?
6The temperature settings for both the driver and passenger sides are the same, but the passenger side is blowing hot air while the driver side is blowing cool air. What's going on, experts?
7My 207's automatic air conditioning is having issues. The air only blows towards the windshield and can't be switched to other directions. The display on the panel works, but it doesn't actually change. The AC compressor starts, but it keeps blowing hot air. The temperature adjustment panel shows the settings, but the temperature doesn't change.
8Is the air conditioning in your cars cool enough at noon when it's 38 degrees? I'm about to melt from the heat.
9Is the warm air blowing on the windshield of your LC120 also weak?
10Is the warm air blowing on the windshield of your LC120 also feeling weak? Is it the same for you guys?
