avatar-image
نايف فهد
Dec 13
Has anyone experienced this situation with the 9th generation Camry? When reversing, I heard a bang, like hitting something, and the handbrake automatically engaged. I checked around and didn't find anything hit.
عبد العزيز إدريسي
عبد العزيز إدريسي2024-12-02 23:49
The radar detects an object and will automatically stop.
The gear lever on this company car is problematic. After shifting to reverse, the detent stays in the engaged position even when you return it to neutral. You have to push it down to disengage. I didn't pay attention today, and when coasting downhill while pressing the clutch, I directly shifted to first gear without pushing the detent down. As a result, the car stalled and now it won't start at all.
If the car wasn't completely stopped before shifting into reverse and you heard a grinding noise, it could potentially cause damage. It's generally recommended to ensure the vehicle is fully stationary before changing gears to avoid any harm to the transmission system.
I feel like the high beam is aiming a bit high. Is there a switch in the car to adjust it? I've looked around but couldn't find anything.
I recently got an 08 Mazda 2 hatchback, 1.3L automatic. It has been driven 130,000 km over 15 years. I've been driving it for about 10 days, mostly commuting in the city with a round trip of 40 km a day, but the fuel consumption is ridiculously high... After the fuel warning light first came on, I added fuel worth 200 yuan, which was 25.6 liters, and drove a total of 247 km. The average fuel consumption was 10.35 liters/km, costing 0.8 yuan/km. After the fuel warning light, the engine light turned yellow as well, what's going on??? I didn't think too much and just drove to the gas station, asked the staff to fill it up, but it could only take 34 liters before the pump stopped. The staff said it was full. Isn't the Mazda 2's fuel tank capacity supposed to be 43 liters? Why is it full so much earlier, is there something wrong? Looking for help, how should I deal with this? Has anyone experienced the same situation?
I haven't driven my Changan for half a month due to a business trip. Today, before driving, I checked a few tires and they looked fine, not flat. After driving about 20 kilometers, the dashboard suddenly showed a tire pressure warning. I got out to check but didn't find anything wrong with the tires. What could be the issue, guys?
Hey fellow car enthusiasts, have you guys ever heard a sound like something hard hitting the metal part of your car door? I'm currently hearing it from the right rear side.
In the past couple of months, I've experienced my car's system crashing twice. The first time, I had to disconnect the car battery and reset to factory settings to get it back to normal. But after about ten days, it happened again. This time, I didn't do anything, and after letting the car sit for an hour, it started working fine again. I'm not sure if it's a hardware or software issue, as I haven't updated the system for quite some time. Has anyone else experienced something similar?
Toyota Toyota Camry
Toyota CamryAED 91,000 ~ 146,390Gasoline & Hybrid
