عبدالرحمن تركي
2024-12-01 09:45
The entire dashboard flashes red a few times and makes a beeping sound, then stops. What's going on? It's not the lane departure system, and it's happening quickly. The entire dashboard flashes red.
نايف حكيم
نايف حكيم2024-12-01 19:19
Active emergency braking system
غازي سعود
غازي سعود2024-12-01 10:33
This happens when I'm getting close to the car in front. I've experienced it several times.
Why is there a beeping sound 3 times in a row while driving, even though everything on the dashboard appears normal?
The "circle A" symbol for the start-stop system on the 2021 GV80's dashboard is flashing continuously, and the RPM won't go above 2500. Pressing the start-stop switch doesn't make any difference. Can anyone help explain what's going on?
During driving, the 2016 Peugeot 301 makes a loud scraping noise from the undercarriage. It happens once every few miles. Sometimes it occurs when turning or braking, but most of the time it's quiet. What could be the issue?
Have you ever experienced the charging process suddenly stopping halfway? I've encountered this several times recently. Sometimes it stops just after charging a few kilowatt-hours, other times it stops at 80% or even at 90%... I'm not sure what's causing it.
When the trunk of the Peugeot 301 is opened and then closed, the dashboard makes a ticking sound, similar to the sound of hazard lights. Does anyone know why this happens?
I have a question for everyone. Occasionally, when opening the door of my 2021 Subaru Outback, the hazard lights flash a few times accompanied by a beeping sound, then it disappears. There's no indicator light on the dashboard, and there's no issue while driving. What could be the reason for this? I've been driving it for a few years and it's the first time I've encountered this situation.
When driving the Kamiq, if a red "P" appears on the dashboard and there's a beeping sound similar to the seatbelt alert, what could be the issue? Can anyone advise? Thanks!!
While driving the KAMIQ, a red "P" appears on the dashboard, accompanied by a beeping sound similar to the seatbelt warning. What could be the issue? Thank you!
My car is a 2.0 naturally aspirated engine. When I gradually accelerate past 80 km/h, the car shakes a few times, and then it stops shaking. However, if I press the accelerator hard, this doesn't happen. I wonder what's causing this.
Toyota Toyota Camry
Toyota CamryAED 91,000 ~ 146,390Gasoline & Hybrid
