Hey guys, does anyone else have the issue where the car doesn't shift gears while going uphill and just struggles? Also, the RPMs go high when going downhill.
Is it normal for the Sharan to shift gears at 3000 RPM when climbing?
The gear shifting feels jerky. When going downhill, just a tap on the brake slows it down to the minimum speed. The fuel consumption is too high, basically 11 liters in the city.
4Is there anyone who has experienced this situation? When shifting from 1st to 2nd gear, the car doesn't accelerate even though the RPM goes up. I have to release the accelerator and then press it again to make it work. What's going on here? Is it a transmission issue or something else? How did you guys solve it?
5Car enthusiasts: Sometimes when driving a small car, the D gear won't shift up. The RPM suddenly goes up, but the gear doesn't match. What could be the reason?
6Does your engine also make a loud noise when the RPM reaches 2000? Especially when going uphill, all I can hear is the roar of the engine.
7Is the MG car lacking power when going uphill? Does it jerk in second gear? Is this common?
8The Volvo C30 2.0D has a normal idle speed of 850±20 RPM when in gear, but the idle speed is high at 950±20 RPM when in neutral. What's going on?
9Does your Jetta automatic also have a noticeable jerk when shifting gears?
10Hello everyone, when driving an automatic Nissan Sunny, what's the situation when I brake and then accelerate, the RPM goes high but the car doesn't move? This often happens when turning as well, the RPM is high but it just doesn't go.
