خالد ميسور
2024-10-26 13:44
Is the Tucson L shorter than the CR-V? If so, is it the whole vehicle or just the engine compartment?
سلمان زبيدي
سلمان زبيدي2024-11-10 23:02
The Tucson is less than 4.5 meters, while the CR-V seems to be over 4.6 meters.
أحمد عمرو
أحمد عمرو2024-11-10 20:10
Go check out the real car! 😁
سعود صلاح الدين
سعود صلاح الدين2024-10-27 15:26
Tucson is taller than CR-V.
عبد العزيز راضي
عبد العزيز راضي2024-10-26 14:20
It's probably just the CRV, the front bumper, that sticks out a bit.
Sometimes when I'm driving my X90 on the highway, there's a humming sound coming from the engine compartment. What could that be?
The range is a bit low, only 278 kilometers, which is less than half of other electric vehicles.
The display shows low battery, the engine suddenly stalls, and the whole car is unresponsive. What could be the problem?
Why does the engine compartment of a 2010 model, registered in 2011, with 83,000 kilometers occasionally make a "da da da da da da da" sound, especially noticeable when starting and just before stopping after driving?
Is the inspection for vehicles older than 15 years required twice a year?
The cigarette lighter fuse for the 1819 model of Yuxiang is located in the fuse box. You can usually find the fuse box under the dashboard on the driver's side or in the engine compartment. Please refer to the vehicle's manual for the exact location and diagram of the fuse box.
Is it true that the salesperson said the first owner gets a lifetime warranty on the whole vehicle?
My car was involved in an accident in 2018, affecting the front bumper and radiator area. It was repaired at the 4S shop. For the past four years, there were no issues during the vehicle inspections. However, this year, the inspection technician said that the vehicle identification number in the engine compartment had been altered. What's going on with this?
The new 40 series' sound insulation is actually acceptable, but the engine roars without much power, and the engine noise is just too much. Can soundproofing the engine compartment help alleviate this issue?
Where should I apply sealant if there's a water leak in the engine compartment? 🤔
Hyundai Hyundai Tucson
Hyundai TucsonAED 86,940 ~ 254,900Gasoline
