حسن اشرف
حسن اشرف
Nov 22
What could be the reason for the gear shift paddle in the Tucson falling into D gear on its own after being replaced?
عمر فارس
عمر فارس2024-11-23 19:06
Manual mode remains unchanged in Sport mode.
أحمد عمرو
أحمد عمرو2024-11-22 20:07
Only the sport mode will lock the gear.
سعود شعبان
سعود شعبان2024-11-22 17:31
Shift the gear to Sport mode.
عبدالرحمن نوري
عبدالرحمن نوري2024-11-22 10:35
In Sport mode, it won't switch to automatic transmission.
خالد عبد له
خالد عبد له2024-11-22 09:54
If you don't operate it for a while, it switches back to automatic mode. I'm curious, why do you have to use the paddle shifters?
What could be the reason for a Haima S5, 2016 model Enjoy Edition, not moving after shifting gears without accelerating?
When the old model Vito is at a red light and you shift from N to D, causing the car to lurch forward, what could be the reason?
What could be the reason for a vehicle with an 8-speed automatic transmission to jerk when shifting from 3rd to 2nd gear?
What could be the reason for not being able to shift gears when the car is cold?
Car enthusiasts: Sometimes when driving a small car, the D gear won't shift up. The RPM suddenly goes up, but the gear doesn't match. What could be the reason?
The battery status is normal. What could be the reason for not being able to start the engine after turning it off?
What could be the reasons for not being able to shift gears?
When shifting from D to neutral, there is a clicking sound. What could be the problem?
Hyundai Tucson
Hyundai TucsonAED 78,500 ~ 254,900Gasoline & Petrol
