The air conditioning doesn't heat unless it's set to maximum. What's the issue?
Hey folks, does the 2015 model have an air conditioning filter? Some say it does, some say it doesn't. Has anyone replaced the air conditioning filter before?
How did you solve the issue with the rear central air conditioning since the NV200 doesn't have central air conditioning?
For the 2017 GWM Haval model with 110,000 km, if the air conditioning isn't blowing air until the fan speed is set to maximum, or the AC needs to be turned off for a few seconds before air comes out, there might be an issue with the blower motor or the air vents. It's best to have a professional check the blower motor and the vent system for any blockages or mechanical issues.
4It's a common issue. The big smell in your car during summer is usually due to the heat causing materials inside to release odors. When you turn on the air conditioning, it helps circulate air and reduce the smell.
5When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
6For the 2017 model, if the central control air conditioning vent is weak and you hear a loud noise from the air conditioning even when it's on maximum, but there's not much airflow, how can this be resolved?
7My 207's automatic air conditioning is having issues. The air only blows towards the windshield and can't be switched to other directions. The display on the panel works, but it doesn't actually change. The AC compressor starts, but it keeps blowing hot air. The temperature adjustment panel shows the settings, but the temperature doesn't change.
8Hey guys, how's the air conditioning in your hybrid Yingku? Mine doesn't seem to cool well, and when I went to the dealership they said that's just how GAC's air conditioning is.
9Is the air conditioning in your cars cool enough at noon when it's 38 degrees? I'm about to melt from the heat.
10The air conditioning was set to level 4, but there was still barely any cold air and the airflow was very weak. What's going on? After a day, it went back to normal. It's really frustrating.
